Seatbelts - harness'
blkcorvair
I figure since Santa Claus may feel so inclined to bring me a harness I should advise him of the correct one to buy. Rules specify H type. (NO Y Type.) I only have one mounting hole in center behind seat. (Which even if I got an H type, bolting them together would create a Y type and this could be a problem?) Or should I get Wrap around harness. ( I assume these individually wrapo around the rollber behind the seat. (Do they require clearance- I am right against the crossmember with the seat back.)
UGGH! Hopefully some of this makes sense....
aeronca65t
I am wrapping mine around a shoulder-height bar in the Escort. You have a similar bar, so that should work for you.
My Spridget is different with two welded mounting points on a shoulder-height bar.
You are correct.....no "Y" type belts allowed.
By the way, be sure to get "FIA tagged" harnesses and not "SFI tagged" belts. The FIA belts are good for 5 years and the SFI belts are only good for 2 years.
Also, if you order them, wait until '08 and insist on 2008 tags. That way, they should be good for an extra year (at least in EMRA....I think the SCCA only allows them for 60 months, which may cause them to expire a little sooner).
By the way, I personally think that allowing SFI belts for only 2 years is overkill and if they are in good condition, I would like to see them OK'd for 5 years.....but that's another story.
Bugeye58
Nial, and Lou, FIA belts come wtih an expiration date tag on them. They expire on Dec. 31st of the year on the tag.
And, the way the rule is written, with some judicious shopping, you can run SFI belts for three years.
I agree, the current SFI belt rule is ridiculous.
Thank you, Dale Earnhart.
Jeff
B
blkcorvair
Thanks guys. Thats what happens when an NHRA guy designs your cage. the little things change. I'll get a harness that wraps around that horizontal bar.
"The difference from racing in straight lines to racing round circuits."
Bugeye58
Lou, you should make sure anything you do to your car is going to be in compliance with the rules of the sanctioning body you are going to be racing with. I don't care if its a beautifully done cage, if it's not in compliance with the rules, it doesn't run on our track until it is. I said earlier, I usually have to turn at least one person away every year, because they have done things their way, rather than read a rule book first.
For another instance, many things that are allowed in the SCCA rulebook aren't legal for vintage, and vice versa.
Jeff
Michael Oritt Retractable two-point seatbelts Austin Healey 12
Y MGB Another question - this time on seatbelts.... MG 2
D Faded Seatbelts Jaguar 12
Bantamfan Seatbelts Spridgets 4
jfarris TR2/3/3A Adding Seatbelts to a TR3 Triumph 4
R TR 3 Seatbelts Triumph 4
CJD TR2/3/3A TR3 Seatbelts Triumph 11
RAC68 Needed - 3-point Seatbelts Austin Healey 10
T 76 midget seatbelts Spridgets 4
brgrmyster Kangol Reflex retractable seatbelts Jaguar 4
brgrmyster TR6 Sourcing TR6 Kangol Reflex seatbelts Triumph 6
Jim_Newman Seats and seatbelts Austin Healey 6
R TR6 TR6 Aftermarket Seatbelts Triumph 4
lbc_newbie Click-it or ticket...78 Midget needs seatbelts! Spridgets 26
Hairyone BE seatbelts Spridgets 1
M ^^ Sprite Seatbelts Spridgets 16
G TR6 TR6 Seatbelts Triumph 2
R 3 point seatbelts, attaching? Austin Healey 9
mrv8q TR6 TR6 Seatbelts Triumph 9
Baz MGB-GT BGT & rear seatbelts... MG 11
D Seatbelts and sunvisors MG 24
wingsandwheels TR6 TR6 Seatbelts, opinions Triumph 7
mgbnew Installing Seatbelts [over the shoulder type] MG 3
bash TR6 TR6 Seatbelts Triumph 4
D Seatbelts Spridgets 3
P MGB-GT Help: BGT seatbelts MG 3
G Do seatbelts increase safety? MG 47
coldplugs 1966 S3 Elan seatbelts Lotus 2
V Elan seatbelts Lotus 2
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
S Wiring Harness Replacement Spridgets 1
B TR4/4A Wiring Harness Triumph 6
Healey Nut Wiring Harness Routing Austin Healey 5
nichola TR6 New harness installed but have a purple problem Triumph 12
J Wiring Harness Austin Healey 5
nichola TR6 Question on new wiring harness Triumph 6
R TR2/3/3A Replace wiring harness in steering column Triumph 61
Ripper01 For Sale- TR6 Wiring Harness Triumph Classifieds 0
R TR2/3/3A Install new wiring harness in steering column Triumph 16
B MGA Solution! 1600 harness in a 1500 MG 1
ckeithjordan TR2/3/3A Wiring Harness Question[s] Triumph 10
nichola TR6 Victoria British wiring harness for TR6 Triumph 6
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
C For Sale MGA wiring harness MG Classifieds 3
C MGA Wiring harness question MG 7
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
RAC68 Harness Layout and attachment to a BJ7 Austin Healey 5
red57 What is correct wire harness outer wrap Austin Healey 17
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
