TR6 Seat Belt Module?
Firsttimer
Recently, I removed the glove box and noticed that the plug that fits into the socket shown below was unplugged. It doesn’t seem to have affected anything that I notice when driving the car. Looking at a wiring diagram it appears to be the “seat belt module”. Since I know when I have my seat belt on, is there any reason the reconnect this module? My thought is the fewer unnecessary electrical items running the better.
Gliderman8
Not only does the module tell you about the seat belt, but it also has an interlock so the car won't start unless you are sitting in the seat AND have your seatbelt on.
The module is problematic since if everything is not working, you are unable to start the car. Most people either have it disconnected or (in my case) just jumper two wires to bypass the safety interlock so the car will start without the seatbelt being engaged.
F
Firsttimer
Thanks Gliderman8. I can’t be sure it didnt come loose when I removed the glovebox. I guess I’ll just try to start it unplugged and then if it won’t I’ll plug it in.
poolboy
If you have a 74 model, there would be a 12 pin plug with a w/o and w/r wire...If a PO didn't already, you should splice those 2 wires together, like the factory did in 75....
pdplot
For those too young to remember, all 1973 cars sold here had a seat belt interlock that made the car impossible to start unless your seat belt was latched. 1974 cars had a ton of smog control crap that made them run poorly.
D TR2/3/3A layout for lap type seat belt Triumph 5
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
M 1972 Midget Seat Belt Replacement Spridgets 4
nichola TR6 Seat belt reinforcing plate question Triumph 15
Michael Oritt Seat belt anchors--introduction Austin Healey 2
B Wanted Kangol Seat Belt Receiver Jaguar Classifieds 5
B Wanted Kangol Seat Belt Receiver Triumph Classifieds 0
I General TR Seat belt dissassembly help Triumph 0
I TR6 Seat belt restoration Triumph 1
C TR6 Seat belt warning bypass for new harness. Triumph 6
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
M TR2/3/3A Another seat belt question Triumph 8
Jeepster Seat belt fixing Austin Healey 4
Jim_Gruber Seat Belt Mounting Points for a BE Spridgets 2
T seat Belt Buzzer Wont shut off Triumph 5
C Stock seat belt color? Austin Healey 11
B seat belt upgrade complate ! MG 1
L 1978 mg midget seat belt replacement Spridgets 3
Stinger TR4/4A TR4A Seat Belt Badge and Side Lamp Lens Triumph 8
mdionne Seat Belt Problem Spridgets 3
mdionne Seat Belt Problem MG 2
HealeyRick Need BJ7 Seat Belt Bracket Location Austin Healey 4
T How did you mount your retractable seat belt? MG 6
I TR6 TR6 retractable seat belt source? Triumph 10
T 3 point seat belt options in a Bugeye Spridgets 5
S Need two of these seat belt brackets Austin Healey 3
I 3 point seat belt installation help Spridgets 3
Jim_Gruber Retractable Seat Belt-Mine has been eaten Spridgets 3
Gliderman8 Seat belt parkers anyone? Triumph 2
HealeyPilot Rear seat belt for 1960 BT-7 Austin Healey 9
T Seat belt question.... MG 4
C Seat belt guide MG 0
J seat belt intallation in late BJ8 Austin Healey 24
Tinkerman TR2/3/3A Seat Belt Mounting TR 3A Triumph 6
tweety I need a Kangol seat belt Spridgets 1
T xj6 Seat Belt Jaguar 1
rlandrum TR2/3/3A TR3A Seat Belt Question Triumph 22
Indnrdr BT7 Seat Belt Mounting Acorn Nuts Austin Healey 0
mrv8q TR6 TR6 Seat belt mounting question Triumph 3
dklawson Spitfire Spitfire - Seat Belt Anchor Bolts [Size?] Triumph 6
milemarker60 Miata Seat Belt Receiver Question Triumph 4
X Seat Belt Holders MG 5
Luke_Healey Was this seat belt a real BMC part? Spridgets 3
A Seat Belt replace MG 3
A Break Warning Light & Seat Belt Extenders MG 3
A MG in NASCAR / Seat belt clips? MG 10
R driveshaft tunnel seat belt eyebolt- BJ-7 Austin Healey 3
W Seat belt warning electricals MG 0
T Seat Belt screw Rover / Land Rover 3
Monark192 Seat Belt Mounting Bolts MG 0
