Approximately between 3400 rpm and 3800 rpm running around 65 mph, I periodically get scuttle shake. I used a dial micrometer checking the drive shaft and found on both ends the shaft is 012 out by the weld on the same side front and back, the center is measuring 025 out also on the same side, other side being 0. Never dealt with such small diameter drive shafts. There also seems to be a little side movement on the spline where it goes into the front yoke. What do you think, replace it or that's not enough to worry about? PJ
