Scuttle shake and tyre pressures
DavidThorn
The car is a late BJ8 with 165 radial tyres on bolt on wheels.
I was running it with pressures of 25 front and 27 rear and had scuttle shake at about 55 mph, the steering also reacted badly to potholes in the road surface,we get a lot of them here in the UK!!
Hitting such a hole would send quite a shudder through the steering , its got a recent Denis Welch steering box and I think all the steering joints are good ,
I recently increased the pressures to 27 front and 29 rear and both issues seemed much improved.
Any thoughts?
David Thorn
John Turney
Here across the pond, we do the "pothole slalom.
I'm told that your new tyre pressures are about right. I run mine at 35 psi all around, although I have 195/65 tyres, to keep from scraping on exiting my driveway.
Do you have the scuttle shake at 55 on smooth roads?
Patrick67BJ8
Any thoughts?
David Thorn
Scuttle shake can also be cause by rear brake drums out of balance, tires out of round( you can balance a out of round tire, but it will not roll true).
steveg Steering column steady brace and scuttle shake? Austin Healey 2
M Scuttle shake. Austin Healey 16
B Scuttle shake finally sorted Austin Healey 23
PAUL161 T-Series Scuttle Shake/Vibration MG 6
S Scuttle Shake Austin Healey 95
5 The scuttle shake mod- I can't decide Austin Healey 7
D whats causing my SCUTTLE SHAKE !!!! Austin Healey 39
richberman Scuttle Shake solutions, necessary? Austin Healey 24
J What is scuttle shake and is there a cure? Austin Healey 9
Randy Harris Scuttle shake at 55 Austin Healey 20
C Rattletrap [ Scuttle Shake ] Austin Healey 46
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
F TR2/3/3A starting scuttle repair Triumph 27
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
C TR2/3/3A scuttle vent Triumph 6
D TR2/3/3A Scuttle uneven on one side Triumph 12
Darwin Spitfire scuttle vents Triumph 0
R More Shroud to Scuttle install Austin Healey 4
L TR2/3/3A Scuttle / front fender attachment Triumph 9
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
C TR6 Scuttle lid spring? Triumph 6
P TR2/3/3A TR3A Scuttle/Windscreen Stanchion questions Triumph 12
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
B How do wipers mount to scuttle top on a 100-6? Austin Healey 16
J Door/scuttle rubber seals Austin Healey 2
AHS TR2/3/3A Can someone please measure the scuttle vent door link length? Triumph 2
S Scuttle Liner/ Footwell Cards Austin Healey 10
H clear coat question on scuttle Austin Healey 7
PatGalvin Scuttle Vent Rubber placement Triumph 4
steveg Scuttle Seal installation article Austin Healey 2
O TR2/3/3A TR3 Windshield to Scuttle Mounting Triumph 1
M Sebring Scuttle Vent Austin Healey 3
H Scuttle Seals Austin Healey 2
curtis BN2 scuttle seal Austin Healey 13
luke44 TR2/3/3A TR3 Scuttle Vent Assembly Triumph 4
tomshobby TR6 putting scuttle door on 76 TR6 Triumph 9
H TR2/3/3A TR3A-Scuttle Vent Ass,y - Parts Missing Triumph 3
luke44 TR2/3/3A TR3 Scuttle Vent Disassembly Problem Triumph 6
C scuttle vent linkage Triumph 4
H TR2/3/3A TR3 Scuttle Vent Questions Triumph 3
ekamm scuttle knob Triumph 6
M TR2/3/3A Tr3 scuttle mechanism Triumph 2
S TR6 76 TR6 Scuttle Vent Triumph 16
O TR2/3/3A TR3 Scuttle Panel Still Needed! Triumph 5
O TR2/3/3A TR3 Scuttle Panel Triumph 8
G Scuttle Vent Adjustment Triumph 1
