whats causing my SCUTTLE SHAKE !!!!
Donny_L
MY 61 ah3000 starts shaking bad when I hit 65mph. So far I've changed the front sway bar bushings, topped off shock oil. I plan on re-packing the front bearings next. Any other suggestions? I'm trying to do the least expensive and easiest ideas first because I have limitd funds and even less know how. LOL ! sad but true
Keoke
This will require that you replace the king pin bushes..
First a removal tool will be require to remove and replace the bushes.
Next a dual adjustable reamer will be required to ream the bushes to the correct size and keep them aligned.
Alternatively two piloted adjustable reamer can be used here,
Adjustable reamers are required because the king pins even if new have slightly but significant different diameters side to side
If you choose to send the work out to a shop make sure they have the proper tools to do this job.---Keoke
Stretch
Lift the front of the car by jacking under both spring plates. You want the springs compressed to about normal ride conditions. See if you can detect play anywhere in the steering components. Push tires and check for play in wheel bearings, king pins, tie rod ends, steering box (wheels straight forward). Helps to have someone hold the steering wheel. Absent any appreciable play your wire wheels probably aren't true. A relatively inexpensive dynamic balance will detect wheel problems.
Michael Oritt
Donny--
I may be stating the obvious but make sure your wheels are well-balanced.
1965AH3000
The most inexpensive checks...as you asked: jack up one front wheel, spin
the tire and check for side to side wobble by watching the center tread groove.
If you have a gauge or pointer great. Next check for up and down tire travel
by spinning the tire and holding a pointer against the tire to see if it goes up and down. If you have either movement more than 1/8 In. tire or wheel is out
of Spec. Repeat with other 3 tires. If all is OK, find a wheel tire shop that can spin ballance them on the car. Regular balance machines do not have the proper cones and spacers to do the job, trust me on this. This procedure should solve the problem as wheels and tires are usually the cause. Hendrix Wire Wheel are THE guys, however with shipping and labor, not a choice on a limited budget.
Healey 100
How old are your tires? I spent a lot of time and money truing, balancing, and aligning wheels with no real effect on the shake. Then I bought new radials, that made all the difference.
The tires I had on before were old but had great tread and looked fine. Apparently they had internal problems, perhaps caused by being parked a lot? Dunno, but I would consider new tires first before replacing wheels, front end parts, etc.
Good luck!
wheelguy
To learn how to read your tires date codes.. go to www.hendrixwirewheel.com
Click on tech tip page and then click on ( READ TIRE DATES )
This will give you the week and year they were made. If it has only 3 numbers instead of 4 they were made in the last centery and are over 11 years old. If they have 4 numbers they were made in this centery. Wheelguy
RAC68
It’s nice reinforcement when you find your thoughts being entertained by others and I agree that each, or any combination, could cause your problem. One missing, however, is wheel alignment. The effects of excessive toe in or out will show up more aggressively at speed when the front end lightens. Before everything, I would suggest you do a quick check on your alignment. If you have any question how, check the archives “Austin Healey Toe in adjustment”, as there was an extensive discussion on this topic.
Good luck,
Ray (64BJ8P1)
wheelguy
I have found that toe in set as close to 0 degrees as possible is best for daily driving. Plus or minus a 1/16th of a inch. Wheelguy
Brinkerhoff
Donny, I see someone asked how old your tires were. I was thinking that too after reading one of your posts saying the car had sat for 35 yrs. ( If I read it right). Were it my car I would raise the front wheels off the ground and spin each by hand as fast as I could too see if any of the four had a hop or side to side drift to it. If you find any, balancing probably won't help. Don't cost nuthin' . If the tires need replacing , don't waste your money putting new tires and tubes on old wheels that are worn out and unsafe and /or the drive splines are worn out. Good luck , Kevin
Donny_L
Thanks guys, the tires and tubes are pretty new. After doing some of the other hands on tests w/ the help of a friend,I'm going to go ahead and order king pin set W/ all the little pieces that come with. Also trunion bushings,A arm bushings and the rebound buffers. what do ya think???
Keoke
I think you headed in the right direction now----Keoke-- :laugh:
BoyRacer
Scuttel shake has nothing to do with worn king pins. If your king pins are badly worn you will have what is called "shimmy" and your steering wheel will be shaking like crazy and your front wheels will be flopping around.
The general rule of thumb is that if your steering wheel shakes it is your front end that is loose. If you feel the shaking in your butt, then back end is loose. However, scuttle shake in a Healey is kind of a hybrid. I suggest that you balance your rear brake drums first before you go spending lots of money on front end procedures.
wheelguy
ALWAYS..ALWAYS..ALWAYS. Get your wheels,tires and drums set up perfect by a expert FIRST. NOT at the corner Exxon station. That will eliminate the biggest cause of scuttle shake. Then you can head inward if needed. Rebuilding your whole front end is putting the cart before the horse.. Wheelguy R.Allen Hendrix
Keoke
--------------------------- :shocked:
------------------------------------------Keoke :laugh:
Patrick67BJ8
I agree!! I bought new wheels and tires it took some shake/shimmy away but it wasn't until I bought new tires & wheels that most os the shake/shimmy went away. Now, 30 years later, I went through the whole process again with tires, etc. but it wasn't until I had the drums balanced that the shake/shimmy went all away. With king pins replaced and new tires/wheels there wasn't much of an improvement. The back area made most of my improvement. Swap a set of wheels & tires with a known good car and see the different before you spend lots of momney!
Patrick
bob hughes
I have renewed my king pins and still have the shakes, perhaps I should start taking more water with it :crazyeyes:
Seriously though, it could be any number of things, for me I am sure the problem is in the back and is possibly the drums or the tyres as they are old and I have seen the wobble in them when they were being balanced.
I would go for the rear end first. best of luck Bob
5
57_BN4
Although I won't get to drive my car for a few more years yet, I can say it must have shaken horridly with all four brake drums being way out of balance. They are easy to DIY balance at home using an electric drill to spin them up on the axle and a felt pen to mark the heavy side. I have removed almost the same amount of metal from the balancing ring again as the factory did and now they all run pretty much dead smooth.
Brake drums IMO should be the first item to balance for any vibration issues as they were clearly not well balanced when new. Probably will add many miles to the rest of the suspension gear without the constant vibration.
Andy.
R General TR Emergency hot wire - because you never know whats next Triumph 2
B Whats my car worth? Austin Healey 5
Got_All_4 TR2/3/3A Whats up with these "a" arms Triumph 1
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
HEALEYJAG Whats it worth>>>3000 MkI Austin Healey 11
catfood Whats wrong with this BN1 Austin Healey 14
CanberraBJ8 Whats this hole? Austin Healey 10
Anthony_S TR2/3/3A Buying a top for my TR3A....Whats best? Triumph 8
CZ_Dave Whats it worth?? MG 3
6 '65 MK2...typical "whats it worth ? " post Jaguar 4
B Gas tank sealer...whats your opinion? Triumph 29
Brinkerhoff Covers , whats best for outside storage? Restoration & Tools 3
toysrrus Whats this belong to? Triumph 3
kodanja Whats the Dif'? Triumph 12
pjsmetana Slot Screw on Angle Drive. Whats it for? Triumph 7
J whats a good sandblaster? Triumph 28
R Whats My Midget worth. Spridgets 22
6 Whats the Proper Way to Remove Tie rods on AH BJ8? Austin Healey 17
UmmYeahOk Knock Offs - Whats the deal? Triumph 28
Stewart So whats going to break next? MG 10
N Spitfire Whats a Spit worth. Triumph 9
jackq 69 Mark IV...whats it worth?? Spridgets 17
Tinkerman Whats this for? Triumph 2
BOBBYR Whats your opinion? Austin Healey 29
Dave Richards Whats Wrong with This Picture MG 12
zimmy primer or primer sealer.....whats the difference? Spridgets 15
H Whats it worth????????????? MG 16
beaulieu Whats in the trunk/ boot of a XK 120 when new ? Jaguar 1
floyd whats the wheel color? Triumph 21
A Whats going on with Ebay bidding and bidders ??? Triumph 17
T TR2/3/3A TR3A overdrive conversion - whats needed Triumph 6
kcbugeye1275 Whats a plinth Spridgets 26
Howard_The_Duck Whats a..... worth? Triumph 2
DNK Whats Up With This. Triumph 20
B Whats the smallest part on a BN1? Austin Healey 14
WidespreadPanic Whats going on over at 6-pack? Hacked? Triumph 11
Harry_Ward Whats in you trunk? Triumph 17
R6MGS Whats it run? Triumph 14
Woodie long weekend things to do, whats ur list? Spridgets 24
Ohiobugeye Whats the key to removing the rear radius arm bush Spridgets 6
G TR6 {TR6 Clutch Pics}. Whats wrong with this picture? Triumph 19
GB1 EBAY- whats wrong with this picture Spridgets 10
J whats the value of:? Spridgets 10
T TR4/4A whats my TR4 worth? Triumph 11
A TR6 tr6 bearings--whats best----Clevite or----? Triumph 11
soren_ak whats teh car with the leather sting across ... Austin Healey 4
L Whats in a Seat MG 2
frankenstang57 TR5/TR250 whats the difference between a 250 & a 4? Triumph 18
EMGEBE OK... whats next.... MG 11
Ed Sweeney Whats worse: Wiring woes or bodywork blunders? MG 15
