Replacement of Bonnet/Hood Hinges/Gaskets/Hardware
G
Hey Guys,
I need to replace my hood hinges this week, and have a question for you. Is it possible for one person to do it, or should there be two? From what I have seen of the installation, it looks like the scuttle portion would be no problem, but it looks like a body is needed to hold and maneuver the hood while the other body attaches the hardware.
Again, I look forward to hearing from you.
Moseso
One person is how I did it. Loosely attach the hinges to the hood. Maneuver it into position. Feed the hinge studs through the scuttle and loosely fit the nuts to them. Wiggle it around and tighten the hinges enough to see how it works. Readjust as required and tighten the nuts.
TR3driver
Great Pumpkin - R.I.P
I've done it by myself, tho it would certainly be easier with two. The trick is to leave the nuts slightly loose at first, so they will hold position but you can scoot things around for adjustment.
Remove the bonnet from the car, and attach the new hinges to it first (loosely, as above). Then one person can set the whole thing into place, with the studs sticking through the holes in the scuttle.
I have also found it advantageous to remove the studs from the new hinges and run a bottoming tap into the threads, then install the studs with Loctite. Some of the studs also had to be cut to length, otherwise they jam against the body and tear up the gasket.
Geo Hahn
Ditto on it being a doable one-person job. Don't recall how, just certain I did it by myself because I had to.
I think the untightened studs give you some fore & aft adjustment to the bonnet... you will want to pay attention to the vent flap to be sure it can open and close w/o binding on the rear edge of the bonnet.
hondo402000
I just took my bonnet off this past weekend by myself, I have a garage, and I opened the bonnet, tied 4 pieces of rope to the joist and then tied each one to the hood the front I went down under the head light area and up underneath and tied to the square cut outs on the underside of the bonnet, the rear toward the windscreen just drop down at each corner and tie in the same square cut outs, unbolt carefully and when loose backed the car away, worked fine, now when I get it repainted I will enlist the help of my neighbor
Mickey Richaud
Good suggestions, all, and here's one to add: Be sure to slip a towel between the hood and the body to protect the paint.
W Bonnet repair/replacement advice Spridgets 18
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
WHT Rocker Arm Shaft Replacement Austin Healey 21
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
D Engine replacement. Rover / Land Rover 0
EWD TR6 Dash Pad Replacement Triumph 3
R TR6 fan shroud replacement Triumph 5
C Replacement wheels Rover / Land Rover 1
B TR4/4A Floor pan replacement Triumph 4
DrEntropy MGB Replacement starter MG 7
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
M General MG Midget MK1 windshield replacement MG 2
M TR6 Replacement Steering Rack ? Triumph 7
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
A TR2/3/3A TR3-A replacement top Triumph 7
C TR2/3/3A Horn Control replacement Triumph 3
nichola TR6 Transmission front seal replacement question Triumph 8
J BN2 Shift Lever Bushing Replacement Austin Healey 6
L 100/6 replacement front seats Austin Healey 7
B For Sale rat-co.com Replacement Frames for all TR models Triumph Classifieds 0
