TR6 Replacement Steering Rack ?
malbaby
Has anyone fitted another steering rack to a TR4-6 to enable less required steering effort when parking.
Maybe another manufacturer with better gearing, or power assisted rack, that has the same dimensions to avoid bump steer etc.
I am aware of the column EPAS systems, but not an easy fitment under the dash, and can be very expensive.
poolboy
When you complete making a low speed 90* turn, does your steering wheel return to center ?
Madflyer
NO My TR 6 has stock rack tire size and foot print is the problem I also replaced steering wheel form 14 inch to 12 inch that made it harder to park but more leg room in and out MOTO- Lita look a like for model year 1973 Check tire pressure and do not park try pull through space. Madflyer
RJS
This summer I replaced my steering rack with a new unit and rebuilt my steering column. The rack is from a place in Oregon. Stock ratio: 3.125 turns lock to lock. Must admit, the steering wheel is incredibly stiff. I need to investigate further if it is the rack itself or the new bushings in the steering column. I am also wondering if everything will loosen up with time/use. I also don't want to mess with the pre-load on the pinion since it is factory set.
I don't mind it but, the steering wheel definitely does not center itself. Oh, and btw, I installed the rack with the solid metal mounts - love it! Also included in the job were new tie rod ends and ball joints. Wow, major improvement.
Regards
Bob
poolboy
I installed a replacement rack a few months ago,,,from Moss, but made in Argentina.
It was very stiff and did not return to center, but I had been told it would loosen up, which it did...Yours may as well within the next few hundred miles
RJS
Poolboy
That is very encouraging news that the steering rack will loosen up with use. Today is a beautiful fall day in CT - I guess I have no choice except to take her out for a nice loooong drive today!
Bob
poolboy
It'll take some driving, Bob, maybe a couple hundred. Take advantage of tight turns in the break-in process.
Got_All_4 Wedge TR7 Steering rack boot replacement Triumph 9
S Steering rack replacement lubrication question Spridgets 15
S Steering rack replacement help requested Spridgets 12
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Bob_Spidell Steering Box Replacement Austin Healey 76
steveg Steering seal replacement on the car Austin Healey 24
mailbox Wedge Steering column bushing replacement Triumph 2
B TR2/3/3A steering box seal replacement TR3B Triumph 4
sim steering pinion replacement ? 58 sprite Spridgets 3
S Steering box oil seal replacement Austin Healey 3
AUSMHLY Steering Wheel Replacement Austin Healey 13
C Lotus Elite Steering Column lock replacement Lotus 5
X Steering column upper bushing replacement MG 1
TR4nut TR4/4A Opinions on a TR4 steering wheel replacement? Triumph 12
S BJ8 Steering Box Peg Replacement Austin Healey 3
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
WHT Rocker Arm Shaft Replacement Austin Healey 21
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
D Engine replacement. Rover / Land Rover 0
EWD TR6 Dash Pad Replacement Triumph 3
R TR6 fan shroud replacement Triumph 5
C Replacement wheels Rover / Land Rover 1
