Steering column upper bushing replacement
X
xsteamer
I read somewhere that you have to take off all the switches off the steering column to replace this bushing. Does this include the ignition switch? I replaced mine a couple of years ago and remember breaking off the screws to prevent tampering. Also Gerry, how do you handle payments for Canadian orders?
tony barnhill
Great Pumpkin - R.I.P
You can contact Gerry at gmasterman@aol.com
From Gerry:
Hi Tony! Thanks for the heads up. I have been unable to sign onto the BCF using the only password/screenname I have in my records. If you would just ask the guy to email me direct until I can get back on the BCF. The second guy may have steering column problems, too. If he can shake is column up and down or side to side by grabbing the steering wheel he likely has bad bearings, too. The sound coming from down low may be his bottom bearing as well. When are you coming down this way again? We ought to get together
L TR2/3/3A Upper steering column bushing Triumph 8
T TR4/4A Upper steering column Triumph 3
X Upper steering column bushing MG 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
M Midget steering column Spridgets 3
B Steering Column Wiring/Sealing Austin Healey 1
Walter74 Steering Column Felt Bushing Austin Healey 3
D Steering Column Adjustment Collet Austin Healey 8
Retired2020 TR250 steering column bushing Triumph 2
ActionJackson Spitfire Steering Column Lock Triumph 3
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
R TR2/3/3A Replace wiring harness in steering column Triumph 61
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
R TR2/3/3A Wiring from the steering column Triumph 7
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
D TR6 Replacing Horn insert in steering column Triumph 11
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
steveg Steering column steady brace and scuttle shake? Austin Healey 2
T TR2/3/3A Is there a Delrin bush available for the top of TR3 steering column instead of felt? Triumph 8
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
T Steering Column Installation Spridgets 6
C Non-Adjustable steering column questions Austin Healey 14
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
SherpaPilot TR6 Steering Column Loose Triumph 8
John_Mc TR6 Steering column rubbler coupler Triumph 8
R TR2/3/3A Installing wiring harness in steering column Triumph 59
B Steering Column Bushing Austin Healey 2
S TR2/3/3A steering column through the body tub Triumph 5
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
G Steering Column Mounting Austin Healey 1
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
B Outer steering column connection to the steering box Austin Healey 6
D TR2/3/3A steering column bushings Triumph 8
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
D BT7 adjustable steering column / steering wheel Austin Healey 1
G TR2/3/3A Steering Column Support for One-Piece Steering Column Triumph 3
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
rjc157 TR6 steering column Triumph 0
S TR6 steering column bushings Triumph 5
Marvin Gruber BJ8 steering column blanking plate seal Austin Healey 1
J TR2/3/3A Split steering column rubber bushing installation. Triumph 4
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
T TR2/3/3A Steering Column Grommet Triumph 4
D Ajustable Steering Column Escutcheon Austin Healey 2
6 Steering Column Spridgets 6
