Rebuilt Brake Calipers
Rut
Whe rebuilds brake calipers or offers rebuilt calipers with a core?
Thanks, Rut
Gerard
Thanks, Rut
Rut,
In my opinion, this is the best guy in the US for any brake or hydraulic work. I've done business w/him for over 10 years and never had better service from anyone. I've personally done over 20 master cylinders with him and have done at least 60-75 more in disc brake master cylinder conversions. ( I developed the disc brake conversion MC's with his help- https://gerardsgarage.com/Garage/Tech/DbrakeUg.htm ) He can do anything, even really odd stuff, but has done plenty of LBC stuff. He even has a special Spridget section on the web site. I assure you you will be satisfied with the work.
You can let Joe know I referred you.
https://www.brakecylinder.com/
JPSmit
Rut, assuming there is no damage to the calipers and the pistons don't need replacing, it's an easy rebuild DIY. PM me your email and I'll send you an article
Rut
Rut
Thanks for the offer...the pistons have pits and rust and need replacement. 1 Piston is stuck and I'm working to free it. If a rebuild is not too difficult Im willing to give it a try. How do you get these things clean enough to paint?
Thanks, Rut
JPSmit
do you have access to a media blaster? Otherwise, assuming you are talking rust rather than dirt, go to the CLR discussion in the Restoration and Car care forum.
Rut
Rut
John,
I read the CLR discussion with interest and probably need to buy stock in them before I begine cleaning. Is a parts washer a good way to go? I've also thought about a small media blasting cabinet to clean up all the parts and pieces. Which one would you prefer?
Thanks, Rut
JPSmit
I have a harbor freight parts washer and I absolutely love it! It's not exactly this one but, pretty much that size. I managed to do pretty much everything on the car with it. Just go to a dollar store and buy every kind of bristle dish scrubber, copper pad, tooth brush, baby bottle washer, steel wool that they make. That being said, I would love to have a media blast cabinet - and the compressor to power it. Still, if I had to choose, I think I'd buy the parts washer and make friends with someone who has a media blaster - that's what I did.
HAN8L1965
Calipers for the most part are easy to rebuild,if you do not have a part washer go to NAPA or Advance they sell a carb cleaner in a gallon can. put your parts in that to loosen them up, I have used this gallon kit for lots of parts. Take the caliper apart and go to a tire shop unless you have your own air compressor. Face the piston towards a large garbage can and apply air to the fluid port, give it a thrust of air and out she'll pop. You can buy new pistons from the usuals and new seals from your local part store, they have them listed under Midget parts.
Mark
bob67bgt
I have a rebuilt one still in the box and several untested ones.
I can make someone a great deal on these. PM for details. Bob
JPSmit
Oh, and, when it comes time to do the work, carb cleaner eats varnish, like off kitchen tables. Just sayin' :blush: :whistle:
Rut
Rut
Thanks guys! I bought a degreaser that is water based (like super Dawn) and soaked them for an hour and then put them in the CLR mix. I hope they will come out perfect and ready for the kits. Last time I looked at the restoration forum I was pleasently surprised by the results of a CLR soak. Bob, I may be giving you a call if I go too far with this thing! BTW, I met a fellow Spridget (or 2) owner tonight and I feel better already. He had names and numbers that are good for the soul!
Thanks, Rut
JPSmit
Rut, when you order the kit, order the seals #180-285 (Moss) that go between the caliper halves - It is so much easier to split the calipers but the rebuild kit doesn't include the seals.
Rut
Rut
I just checked on the calipers and all the parts and pieces I'm soaking in the CLR mix and it's apparent that the result is not going to be as good as the pictures on the restoration forum. The rust is cleaning up, but there is a dark brown to almost black discoloration of the metal. This discoloration partially comes off with a little elbow grease, but the end result will be different from the posted pictures. I may media blast after I get thru with this soak.
Rut
JPSmit
casting colored rattle can paint - looks wonderful!
nomad
What is CLR? Is it phosphoric acid for rust? If it is that can create a coating.
Kurt.
The_architect
CLR is Calcium-Lime-Rust, a household cleaning product you can find at Home Depot, etc. People use it in a 50/50 mix to take off rust. Pretty expensive to do it that way, though. There is a thread on the BCF restoration forum discussing this right now.
You'd put phosphoric acid on afterward to keep surface rust from reforming.
Charlie
Hairyone
When I did mine, after stripping them down I figgured there was only steel bits left, so I put them in the log burner to remove all the crud. Then wire brushed off the ash. Worked a treat.
The_architect
tdskip,
I have no idea whether you can get that off where the seals go or not. I just was answering the question, what's CLR?
Charlie
Rut
Rut
Update on the CLR caliper soak. I did the 50-50 mix and soaked for roughly 30 hours and the results were not as dramatic as the cylinders on the restoration forum. I did a little manual wire brushing and returned them to soak some more with a little extra CLR. They are starting to look pretty good and if I leave them I think the will clean up nicely. The grooves for the seals are cleaning up well also and I did forget to mention that you remove the seals prior to soaking. As always, 'your results may vary', but I think it will be worth it. My biggest problem is waiting on something to work...kinda like sitting in traffic waiting on a wreck or road work, I'd much rather be moving!
Rut
tosoutherncars 1275 / 1500 brake MC... Can they be rebuilt? Spridgets 7
L new or rebuilt brake MC MG 2
D Brake master cyl. New, rebuilt MG 2
poolboy For Sale REBUILT Carbs for TR6 Triumph Classifieds 0
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
D The best place to get shocks rebuilt. Spridgets 8
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
D Starting After Carbs Rebuilt Austin Healey 30
S TR2/3/3A problem just rebuilt SU carbs Triumph 28
Csarneson Storing a newly rebuilt engine Austin Healey 25
Got_All_4 TR6 Engine pulley dampener 69 vs 70 also new or rebuilt Triumph 1
BJ8Healeys For Sale Rebuilt BJ8 overdrive unit for sale Austin Healey Classifieds 0
steveg HD8s easily rebuilt at home Austin Healey 4
D Need to get a vaccuum advance rebuilt Jaguar 2
K TR2/3/3A Rebuilt steering has creative fix for NA worm bearing! Triumph 4
vickxxx T-Series Distributor rebuilt MG 2
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
S My recent decision regarding oil in a '66 3000 with a rebuilt engine Austin Healey 101
jfarris TR2/3/3A Rebuilt SU Carbs - Car Won't Start Triumph 7
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
M rebuilt gauges Spridgets 10
gbtr6 General Tech What oil to use in the gearbox, not rebuilt. Triumph 9
gbtr6 TR6 Prime oil pump in rebuilt engine... Triumph 10
britlover TR4/4A Where can I get an A-type TR4A Trans rebuilt in SE Michigan? Triumph 9
C BJ8 Rebuilt Engine and Carbs - Vapor Lock and Misfires when hot Austin Healey 7
cmacmillan TR6 now what have I done? choke on rebuilt carbs.... Triumph 6
J Starting rebuilt engine ! Austin Healey 8
F TR2/3/3A I just installed a rebuilt C39 Generator on my TR3 Triumph 11
bugedd Front end rebuilt help Spridgets 6
5 How not to start a freshly rebuilt 100/6 engine Austin Healey 30
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
T TR4/4A Breaking in a new rebuilt engine Triumph 7
Sopwith_Camel Rebuilt engine! Spridgets 8
R TR6 TR6 engine rebuilt Triumph 52
TulsaFred Rebuilt 1275 slowly getting dialed in Spridgets 14
TulsaFred First start trouble rebuilt 1275 Spridgets 29
MGTF1250Dave TR2/3/3A TR3 Engine Rebuilt & Installed Triumph 7
M Rebuilt carbs / Idle racing to 3000 Triumph 16
PATR8 First long ride on my rebuilt 8 motor Triumph 3
S old question maybe?, rebuilt engine Triumph 3
B TR2/3/3A No oil to rockers on rebuilt TR3 Triumph 10
S Rebuilt clutch parts Austin Healey 4
M Rebuilt Seat Spridgets 1
N Checking a rebuilt engine Austin Healey 15
