rebuilt gauges
mightymidget
Just couldnt sell my Bugeye project, so trying to get myself involved in a plan to stay focused on rebuild of my 59 Bugeye, So made list.
On my list for this year is to install all gauges in the dash. What is everyone doing? Trying to find NOS/NIB, finding good used? My perferred would be to have my instruments rebuilt. Anyone doing this?
Also seems fuel/sending unit match is critical, suggestions on easiest way to do this properly. Want to install fuel cell do need to get correct sending unit matched to gauge.
This Bugeye is being rebuilt piece by piece, not restored to a car show winner, so not sure if it is OK to use different year gauges, I am planning on orginal big number speed/tach
Also Peter rebuilt complete disc sudpension for me, still in boxes, what about rack/pinon ? Buy new, any venors rebuild?
drooartz
For gauges Nissonger comes recommended, also Palo Alto Speedometer. Rebuilding a set makes the most sense, that way you know you have something that will work as well as possible. I'm also going to have my tach converted to electronic guts as I'll be using an alternator (Nissonger can do that, others as well I'm sure). I like the original Bugeye gauges, so I'll be using a rebuilt set of those for Penny.
Roger
Bronze
Using an alternator doesn't involve tach conversion.
Replacing points and condenser by electronic triggering, like Pertronix, often does though.
dklawson
If the car is outfitted with the mechanical generator driven tach, the alternator conversion does require a gauge change. The Smiths RVI model tachs (loop of white induction wire on the back of the gauge) are the ones that typically don't work with electronic ignitions. The later RVC types work like a "modern" tach and are OK with aftermarket electronic ignitions.
Regarding the fuel cell and sending unit.... The early cars did not have a voltage stabilizer for the fuel and temperature gauges. The sending units have a variable resistance from something close to 80 or 90 Ohms = Full to zero (0) Ohms = empty. The 90 to 0 calibration (full to empty) was used by some Chevrolet cars so look for an aftermarket sender in that range for your fuel cell. The calibration will almost certainly not be an exact match between the Smiths gauge and aftermarket sender. The gauges are fairly easy to calibrate to exactly match the sender. Read over the pages at Barney Gaylord's MGA-Guru web site. He explains how the gauge works and then how to calibrate it. Start with the links below. There are several pages of very informative text and photographs.
How the early fuel gauges work...
https://mgaguru.com/mgtech/electric/fg_01.htm
How to calibrate the early fuel gauge...
https://mgaguru.com/mgtech/electric/fg_06.htm
drooartz
Yup -- Bugeyes use that sort of mechanical tach, driven off the back of the generator. It is nice to be able to switch it over while keeping the original look. I really like the Bugeye gauges, and it's nice to keep it stock looking.
LarryK
I'll second Nissonger. My guy with the MK VII Jag just sent his in and they were cleaned and rebuilt, including making clock digital with analog face, and returned within a week. Clock has bee absolutely accurate for 2 weeks, so far.
drooartz
What about the rack and pinion?
Just checked, and you can get new racks from Moss (even RHD ones from Moss Europe for weirdos like me). They're pretty durable, but replaceable if needed. Don't know if anyone rebuilds them, others may have more info.
Jim_Gruber
I'm going a different route for Bugsy II and going with Speedhut GPS speedo and matching tach. I'm upgrading to a 5 speed and alternators. I eliminate the need for a speedo conversion adapted box which are notitmriis for reliability and electronic tach will work with my - grounded BE without worry.
poolboy For Sale REBUILT Carbs for TR6 Triumph Classifieds 0
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
D The best place to get shocks rebuilt. Spridgets 8
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
D Starting After Carbs Rebuilt Austin Healey 30
S TR2/3/3A problem just rebuilt SU carbs Triumph 28
Csarneson Storing a newly rebuilt engine Austin Healey 25
Got_All_4 TR6 Engine pulley dampener 69 vs 70 also new or rebuilt Triumph 1
BJ8Healeys For Sale Rebuilt BJ8 overdrive unit for sale Austin Healey Classifieds 0
steveg HD8s easily rebuilt at home Austin Healey 4
D Need to get a vaccuum advance rebuilt Jaguar 2
K TR2/3/3A Rebuilt steering has creative fix for NA worm bearing! Triumph 4
vickxxx T-Series Distributor rebuilt MG 2
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
S My recent decision regarding oil in a '66 3000 with a rebuilt engine Austin Healey 101
jfarris TR2/3/3A Rebuilt SU Carbs - Car Won't Start Triumph 7
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
gbtr6 General Tech What oil to use in the gearbox, not rebuilt. Triumph 9
gbtr6 TR6 Prime oil pump in rebuilt engine... Triumph 10
britlover TR4/4A Where can I get an A-type TR4A Trans rebuilt in SE Michigan? Triumph 9
C BJ8 Rebuilt Engine and Carbs - Vapor Lock and Misfires when hot Austin Healey 7
cmacmillan TR6 now what have I done? choke on rebuilt carbs.... Triumph 6
J Starting rebuilt engine ! Austin Healey 8
F TR2/3/3A I just installed a rebuilt C39 Generator on my TR3 Triumph 11
bugedd Front end rebuilt help Spridgets 6
5 How not to start a freshly rebuilt 100/6 engine Austin Healey 30
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
T TR4/4A Breaking in a new rebuilt engine Triumph 7
Sopwith_Camel Rebuilt engine! Spridgets 8
R TR6 TR6 engine rebuilt Triumph 52
TulsaFred Rebuilt 1275 slowly getting dialed in Spridgets 14
TulsaFred First start trouble rebuilt 1275 Spridgets 29
MGTF1250Dave TR2/3/3A TR3 Engine Rebuilt & Installed Triumph 7
M Rebuilt carbs / Idle racing to 3000 Triumph 16
PATR8 First long ride on my rebuilt 8 motor Triumph 3
S old question maybe?, rebuilt engine Triumph 3
B TR2/3/3A No oil to rockers on rebuilt TR3 Triumph 10
S Rebuilt clutch parts Austin Healey 4
M Rebuilt Seat Spridgets 1
N Checking a rebuilt engine Austin Healey 15
Rut Rebuilt Brake Calipers Spridgets 31
smaceng Rebuilt instruments...Bah! Spridgets 19
Jim_Gruber A Late Christmas Present - Rebuilt Wishbones Spridgets 20
rikiwho123 starting rebuilt 1300 for 1st time Triumph 7
