Re-Attaching Choke Cable to Pull...
noutlaw
Member
Well this a.m. was starting my BJ8 - pulled the choke cable knob out, twisted to lock (worked fine)... then was starting it again - i guess i pulled too hard because the knob and metal piece came out of the dash...
So my question is - how to re-attach? From some other threads it sounds simple - - - ???
do I simply unhook it from the enginebay attachment point cable - push back up and "out" (not all the way) then somehow re-attach in the groove, then pull it back in and re-attach to the carb attachment?
It's tough to pull because one of my carbs cable is pretty hard to pull (i'll check on that next)... one is really easy.
Any help would be great.
Keoke
Hi noutlaw, If the cable did not break you can reattach it to the pull. First in the engine bay disconnect it from the block.Now attach a long string on to it and pull it out from the dash side.Using a 1/16" drill open up the hole in the pull's shaft and drill one in its trough . Using a soldering iron tin both ends of the cable ,this tinning must be done cleanly.Now insert the cable in the pull shaft hole while heating it. Once the cable is back in the shaft add a bit of solder in the hole drilled in the trough.Reattach the cable to the string and pull it back through the cable and set the cable stop.---Fwiw---Keoke
N
noutlaw
Member
does it make sense that the cable (it appears) used to go straight into the shaft? maybe i could simply drill straight into it and then solder it back straight in?
Keoke
Yep, it sure did noutlaw, and thats what the instructions say to do--Keoke /ubbthreads/images/graemlins/grin.gif
N
noutlaw
Member
got it - I read it wrong, but now it makes complete sense. Darn - I was hoping for a hammer related task... /ubbthreads/images/graemlins/smile.gif
One More question - is the cable a specific diameter size? e.g. to get a new one...
Keoke
Yep, if you want to replace the cable use the same procedure I outlined, but go to a bicycle shop and buy a replacement brake/gear shift cable ,Just the wire cable, to make the repair.---Keoke /ubbthreads/images/graemlins/yesnod.gif
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
J Attaching BT7 Dash Facia Panel Austin Healey 2
Cutrog1 Attaching pictures while editing FORUM Navigation Questions 7
J Attaching new BJ7 Dashboard To Body Austin Healey 7
J Attaching BJ7 Oval Chrome Dash Molding Austin Healey 6
T TR4/4A Attaching headlight trim ring Triumph 6
Popeye TR4/4A Attaching rear of seat to seat slides...? Triumph 3
M Attaching Info Plate to Engine Spridgets 1
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
T TR4/4A Attaching top dash pad on a Tr4a Triumph 8
Rut Attaching Hardura Spridgets 2
F J hooks an wing nuts for attaching hard top to body BT-7 - anyone got photos? Austin Healey 5
Rob Glasgow Attaching a video Austin Healey 1
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
T TR2/3/3A Attaching HS6s to the stock TR3 manifold. Triumph 3
J Need help attaching photos FORUM Navigation Questions 2
Brosky Wedge TR8 Seat attaching bolt measurements Triumph 13
Tinkerman TR2/3/3A Attaching the temp capillary to the fuel line. 3A Triumph 13
Tinkerman TR2/3/3A TR3A Dash Clamp Attaching Point Triumph 10
D Attaching Rear Wings Austin Healey 9
S TR2/3/3A heater attaching piece tr3 Triumph 4
crya Tricks for attaching door pulls on BJ8?? Austin Healey 8
C Attaching door waist molding Austin Healey 2
amcboy TR6 Question about TR6 top velcro attaching... Triumph 3
jjbunn Re-attaching the hood Triumph 2
M BN4 Capillary tube attaching Austin Healey 2
R 3 point seatbelts, attaching? Austin Healey 9
Woodie attaching the bonnet Spridgets 5
AUSMHLY Attaching the quarter panel Austin Healey 6
AUSMHLY Attaching the quarter panels Austin Healey 8
AUSMHLY Attaching the quarter panels Austin Healey 1
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
D BT7 Choke Assembly Austin Healey 18
P MGB Zenith water choke gasket needed MG 4
D Choke Cable Length Austin Healey 0
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
L MGB 1977 MGB will only run on full choke MG 53
SherpaPilot TR6 Choke Assembly Triumph 0
M Choke Linkage Austin Healey 3
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 TR6 Choke Cable Lubrication Triumph 5
