Tricks for attaching door pulls on BJ8??
crya
Member
Hey all,
I'm just doing some first aid on my healey before one day it goes in for resto. In pulling the door panels to do some windo work, I discovered that the door pull won't stay attached to the door sheet metal because somehow the holes have been damaged to the point that the screw just spins. Now I suppose I could try to just use a bigger screw to attach but not sure a bigger srew will fit through the hole in the door pull. Anybody have any tricks for fixing the hole? Would I tap and die the thing?
Help.
Thanks.
AUSMHLY
The kiss approach would be to use a larger diameter screw, but one that has the same size phillips head. You should be able to find those specialty screws at your local car upholstery/top shop.
You could rivet another thin piece of sheet metal (behind or in front of the door panel) over the holes and drill new holes.
Others will chime in with other/better ideas.
Cheers,
Roger
Keoke
Yep! if it is going in for resto let the resto people fix the problem. What do you think of that??.__Keoke- :laugh:
GregW
Platinum
You might try gluing a couple speed nuts behind the enlarged holes.
Hangtown Healey
The existing metal around the hole didn't just dissapear. It is still there. Try tapping the metal around the hole flat again if you can get a tool in there. Maybe a air hammer with a bucking bar might close up the hole enough.
crya
crya
Member
All great info. Thanks guys, I'll try some of the above suggestions. Can't wait to let resto people fix it, that is many, many years down the road. :smile:
Keoke
Well I misread your post sorry. However,any screw with a maximum diameter of 3/16" will go through the hole in the door handle. Just be care full and keep the length short or you will damage the window glass. A larger screw is the method most generally used in these cases--Keoke
Genos2
You could always pop-rivet another piece of metal behind holes,slightly larger,perhaps thicker, drill pilot hole & reattach.No one would know it was there but you. cheers Genos2
AUSMHLY
Genos2, I like the way you think!
Were you looking over my shoulder when I wrote that answer at test time, lol.
Cheers,
Roger
Michael Oritt Fresh air 4" hose installation tricks Austin Healey 23
dklawson General Tech Brake Maser Cylinder Pushrod Boot Installation Tricks? Triumph 2
K Tricks or Best Way to Install Front Fenders? Austin Healey 14
J AC air filter tricks and maintenance Other British Cars 0
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
Rob Glasgow Basil's new tricks Austin Healey 6
JodyFKerr Tips & tricks on installing upright air compressor Restoration & Tools 15
tr6nitjulius Shots of the Month [Nov] Tricks & Treats Triumph 2
60Bugeye Sprite Body Work Tips & Tricks For A Novice? Restoration & Tools 24
glemon stupid human tricks mechanical advance Triumph 25
58Custom Any tricks to changing front wheel bearings? Spridgets 7
RickB Tricks removing old tenax fasteners? Need 4 tall.. Spridgets 11
TR4nut TR2/3/3A Radiator removal TR3A - any tricks? Triumph 12
58Custom Any tricks to replacing fuel pump points? Spridgets 3
58Custom What are the tricks to balancing wire wheels? Spridgets 8
regularman Any windshield installation tricks, tips? Spridgets 17
J New member needing windshield replacing tricks Spridgets 3
Bruce_B Cutting the car for a dual MC setup hints/tricks? Spridgets 23
M Tricks for Alternator Removal 87 XJ6 Series III? Jaguar 8
J Front wheel cylinders [discs] -- any tricks? Triumph 3
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
J Attaching BT7 Dash Facia Panel Austin Healey 2
Cutrog1 Attaching pictures while editing FORUM Navigation Questions 7
J Attaching new BJ7 Dashboard To Body Austin Healey 7
J Attaching BJ7 Oval Chrome Dash Molding Austin Healey 6
T TR4/4A Attaching headlight trim ring Triumph 6
Popeye TR4/4A Attaching rear of seat to seat slides...? Triumph 3
M Attaching Info Plate to Engine Spridgets 1
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
T TR4/4A Attaching top dash pad on a Tr4a Triumph 8
Rut Attaching Hardura Spridgets 2
F J hooks an wing nuts for attaching hard top to body BT-7 - anyone got photos? Austin Healey 5
Rob Glasgow Attaching a video Austin Healey 1
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
T TR2/3/3A Attaching HS6s to the stock TR3 manifold. Triumph 3
J Need help attaching photos FORUM Navigation Questions 2
Brosky Wedge TR8 Seat attaching bolt measurements Triumph 13
Tinkerman TR2/3/3A Attaching the temp capillary to the fuel line. 3A Triumph 13
Tinkerman TR2/3/3A TR3A Dash Clamp Attaching Point Triumph 10
D Attaching Rear Wings Austin Healey 9
S TR2/3/3A heater attaching piece tr3 Triumph 4
C Attaching door waist molding Austin Healey 2
amcboy TR6 Question about TR6 top velcro attaching... Triumph 3
jjbunn Re-attaching the hood Triumph 2
M BN4 Capillary tube attaching Austin Healey 2
R 3 point seatbelts, attaching? Austin Healey 9
Woodie attaching the bonnet Spridgets 5
N Re-Attaching Choke Cable to Pull... Austin Healey 5
AUSMHLY Attaching the quarter panel Austin Healey 6
AUSMHLY Attaching the quarter panels Austin Healey 8
