Hi all,
As I have posted (https://www.britishcarforum.com/bcf...hesive-for-open-cell-foam-seat-rebuild-(TR4A) and https://www.britishcarforum.com/bcf/showthread.php?108012-Seats-left-right and https://www.britishcarforum.com/bcf/showthread.php?108012-Seats-left-right), I am rebuilding my TR4A seats. So far, so good - thanks to the article by Alan Turner and many other posts here at BCF.
I am looking at how the seats connect to the seat rails. I have bought new rails from TRF, as the bottoms of the old ones were rusted beyond salvage.
Three questions:
1. The front of the seat has two holes. Through which is the seat mounted?
2. The rear of the seat has a "clip" to connect it to the seat rail, p/n 613303. This part seems to be NLA, and was missing from my seats when I disassembled. How important is this piece? I would imagine when sitting in the seat, with a belt, the seat belt would provide the main force holding the seat in place.
3. I have the TRF seat buffer kit. How is this installed? It includes six washers, a bolt, a nut and the rubber buffer. Washers are a small lockwasher, two "normal" 10-32 washers, and three large diameter washers. What I did was put the lockwasher on the bolt, put this through the buffer, put three large washers under the buffer, and thread this into the threaded hole on the seat bottom. The "normal" washers do not fit inside the buffer, thus only used the lockwasher. On three of the four buffers, the bolt protruded far enough into the seat that I was able to put the nut behind the welded nut on the seat, acting a little as a locknut. Not sure if this is too critical, however curious if I missed something?
Three questions:
