TR6 Question about TR6 top velcro attaching...
amcboy
Got my new top seals from TRF. THey look good, but my question is about the velcro...
What kind of glue (if any) should I use?
I appears that the lower "flap" will end up under the channel for the window seal.
I'm assuming that I should use weatherstrip adhesive or something to keep it there and to attach the top "flap" to the inside of the frame (after folding it over...)
On the right track?
Completley out to lunch.
Do I need 3M icky-pucky #78 or something special?
Working alone 6P to 6A today and tomorrow, so I'll have lots of time to work on it!
Thanks in advance!
Brosky
You will want an adhesive that will hold them tightly to the metal frame, which means that all of the old crap needs to be removed and cleaned perfectly.
You must also give it the proper setup time, because you need to be able to stretch the top over on to the velcro and have it hold when it's cold.
Tomster
Contact Velcro Directly!!! No point in ruining any of the components
They are incredibly helpfull and willing to answer (my stupid) questions
amcboy
amcboy
I ended up using 3M weatherstrip adhesive.
Worked 2 back to back 18s with 1 hour off between.
Plenty of time to set.
Worked good!
Now, off to bed.
trrdster2000 TR6 TR6 top question Triumph 7
E TR6 TR6 flip-up bonnet question Triumph 4
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
B TR6 TR6 1976 Clutch Choice Question Triumph 3
J TR6 TR6 Differential Rebuild question Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
J TR6 TR6 Brake Question Triumph 1
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
Gerry M TR6 TR6 Steel Wheel Question Triumph 3
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
J TR6 '73 TR6, Wiring Question. Original Owner Triumph 5
TR3TR6 TR6 Question about a TR6 J overdrive Triumph 12
sundown TR6 1973 TR6 flasher question Triumph 6
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
S TR6 Quick TR6 alternator question Triumph 6
TR6BobNF TR6 TR6 Dashboard Hinge Question Triumph 3
W TR6 Question on Steering Wheel Puller for 1974 TR6 Triumph 10
I TR6 75 TR6 vacuum hose question Triumph 2
B TR6 1972 tr6 orignality question Triumph 3
W TR6 carb question tr6 Triumph 1
M TR6 TR6 Master Cylinder Rebuild Question Triumph 10
I TR6 TR6 paint question Triumph 8
Coyote1 TR6 TR6 Header Rail Question Triumph 4
gbtr6 TR6 Question on TR6 trunnions and inner tie rod ends Triumph 6
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
B TR6 TR6 Boot Cover Question Triumph 4
G TR6 TR6 caliper/hose fitment question [VB] Triumph 3
mgedit TR6 Transmission Question TR6 in TR4 ... will it work? Triumph 4
B TR6 1972 TR6 Differential Rebuild Question Triumph 3
hondo402000 TR6 TR6 Amp Meter question Electrical guru needed Triumph 4
S TR6 TR6 Bumper question ?????? Triumph 3
hondo402000 TR6 Another TR6 wiring question Triumph 5
hondo402000 TR6 TR6 Wiring/amp gauge question Triumph 8
G TR6 TR6 caliper question [Toyota 4 piston?] Triumph 2
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
hondo402000 TR6 TR6 Clutch question Triumph 5
glemon TR6 obscure tr250 tr6 seat rail question Triumph 4
W TR6 TR6 Differential Question. Triumph 6
T TR6 Question on TR6 throw out assembly Triumph 9
W TR6 TR6 Timing chain oil seal question Triumph 3
R TR6 Front TR6 Suspension Question... Triumph 7
wangdango TR6 TR6 solex question? Triumph 16
B TR6 This question is for the TR6 restorers...... Triumph 7
CinneaghTR TR6 TR6 Lower Wishbone Arm Question Triumph 3
Z TR6 Question about rebuilt TR6 calipers Triumph 3
