hondo402000
I am in the process of rewiring my 71 TR6, in Dan masters book he suggest running a large wire from the uprated alt directly to the battery positive side. I assume its to take some of the load off the amp meter, Well since I put a new wiring harness in I ran a second brown white 65 strand wire from the alt to the amp meter and a second brown wire from the amp meter to the starter, effectly doubling the carring capacity. I have had the amp meter apart before and inside there is a loop of solid copper wire that goes from one terminal to the other, QUESTION, should I and do I need to double the size of that loop of solid wire inside the amp meter. Looks easy enough to do
and no I am not going to replacing the amp meter with a volt meter
Hondo
Hondo
