TR2/3/3A Attaching HS6s to the stock TR3 manifold.
TRTEL
Anyone out there made this switch? Biggest problems/issues, like linkage perhaps? Thanks.
trrdster2000
Tom, best I remember, you will need all the linkage between the carbs as the choke is controlled by a single bar and the cable comes in from the top you may have to cut it to clear the bonnet. You may have to reverse the push rod to get a good push and full throttle. Couple of knit picking adjustments but you will be so happy not getting all the leaks in the choke housing.
Wayne
TR3driver
Great Pumpkin - R.I.P
In addition, the throttle turns the opposite direction on HS6 vs H6.
Simmo
I just did exactly that.
I bought a new set of HS6 from Joe Curto in New York.
The deal was worth every cent of the extra cost of the postage to Australia.
Joe also supplied a TR6 bracket and linkages which fits between the two lower carburettor flange bolts, I suspect its the same as a TR4 bracket.
A small amount of playing around makes the linkages work like a dream and no longer do you have to have an arm like Popeye to pull the choke although you have to re route the cable so it pulls from the top
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
J Attaching BT7 Dash Facia Panel Austin Healey 2
Cutrog1 Attaching pictures while editing FORUM Navigation Questions 7
J Attaching new BJ7 Dashboard To Body Austin Healey 7
J Attaching BJ7 Oval Chrome Dash Molding Austin Healey 6
T TR4/4A Attaching headlight trim ring Triumph 6
Popeye TR4/4A Attaching rear of seat to seat slides...? Triumph 3
M Attaching Info Plate to Engine Spridgets 1
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
T TR4/4A Attaching top dash pad on a Tr4a Triumph 8
Rut Attaching Hardura Spridgets 2
F J hooks an wing nuts for attaching hard top to body BT-7 - anyone got photos? Austin Healey 5
Rob Glasgow Attaching a video Austin Healey 1
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
J Need help attaching photos FORUM Navigation Questions 2
Brosky Wedge TR8 Seat attaching bolt measurements Triumph 13
Tinkerman TR2/3/3A Attaching the temp capillary to the fuel line. 3A Triumph 13
Tinkerman TR2/3/3A TR3A Dash Clamp Attaching Point Triumph 10
D Attaching Rear Wings Austin Healey 9
S TR2/3/3A heater attaching piece tr3 Triumph 4
crya Tricks for attaching door pulls on BJ8?? Austin Healey 8
C Attaching door waist molding Austin Healey 2
amcboy TR6 Question about TR6 top velcro attaching... Triumph 3
jjbunn Re-attaching the hood Triumph 2
M BN4 Capillary tube attaching Austin Healey 2
R 3 point seatbelts, attaching? Austin Healey 9
Woodie attaching the bonnet Spridgets 5
N Re-Attaching Choke Cable to Pull... Austin Healey 5
AUSMHLY Attaching the quarter panel Austin Healey 6
AUSMHLY Attaching the quarter panels Austin Healey 8
AUSMHLY Attaching the quarter panels Austin Healey 1
J Disappointed in rebuild kit for the HS6s Triumph 9
G Lesson learned replacing Strombergs with SU HS6s Triumph 17
D Stock Camshaft TVR 0
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
nichola TR6 Stock exhaust sound... short video Triumph 4
Joel Lester TR2/3/3A Are all "stock" camshafts the same? Triumph 9
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
S TR2/3/3A stock fog light Triumph 2
PC Actually in stock? Spotted 0
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
R Upgraded rod bolts for stock rods Austin Healey 1
S New Build Stock Wheels? Spridgets 38
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
B Wanted stock Bj8 distributor Austin Healey Classifieds 1
