Wedge Petosin coolant [red or blue] in a TR8?
philman
I purchased some petosin coolant (reccomended) for my saab and was wondering if it was good for the Rover v8 alloy block? It's advertised to last longer than the green stuff, but does it have the same reputation as dexcool (orange) coolant?
Phil, that's original equipment for BMW, Mercedes, and a lot of the high end European cars.
It's the only coolant my buddy handles at his Euro import warehouse/jobber.
Good stuff. I don't see why it wouldn't be an excellent choice for the Rover, provided you flush the system thoroughly before changing over.
Jeff
I think I misspelled the coolant it's "pentosin" I think. The advertising says that it is a "lifetime" coolant.
hey phil, the pentosin coolant is good stuff, the point of it is to be used in aluminum engines or radiators because the green coolant is corrosive to aluminum. i would definitly use that or the "gm" orange coolant in your car.
Randy
MAKE sure that you know the electrical conductivity factors of this coolant in relation to you rad and jackets. As some require particular electrovalent values
Major corrosion risk
MAKE sure that you know the electrical conductivity factors of this coolant in relation to your rad and jacket requirements. As some require particular electrovalent values
I would be using it with a freshly rebuilt engine, so flushing the block of old coolant wouldn't be necessary.
S Spitfire Cyl head coolant hose fitting Triumph 1
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
B TR6 Triumph tr6 coolant leak Triumph 4
B Oil (or Coolant) Leak Austin Healey 10
FlyingCat Spitfire Losing Coolant Triumph 12
M TR6 1973 TR6 Coolant Type? Triumph 5
R Coolant temperature gauge Spridgets 8
Govtslug TR6 Coolant Temp Q Triumph 4
T TR2/3/3A TR3 coolant hoses Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
nevets Coolant Temperature Austin Healey 13
L BMC A-series: Oil in coolant British Motor Corp 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
K TR2/3/3A Radiator coolant level? Triumph 5
M TR6 '72 TR6: Oil in Coolant Triumph 25
W TR2/3/3A location of the coolant drains on a tr3a Triumph 4
Got_All_4 Wedge Tapered coolant hose for a PI car. Triumph 3
Paulus TR4/4A Coolant pressure Triumph 5
D TR2/3/3A Coolant tap on TR3 block Triumph 3
gfholl Coolant Leak Spridgets 9
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
S TR2/3/3A Replacement of Engine Coolant Drain Triumph 3
B All the coolant in the wrong place Spridgets 17
G TR4/4A Thoughts on my coolant Triumph 12
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
JFS Wedge Low Coolant Light Triumph 7
Boink Waterless Coolant - thread from the AH forum Spridgets 18
PatGalvin TR2/3/3A Coolant System Hoses Slipping Triumph 5
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
Jim_Gruber Replacing Spridget Coolant Spridgets 21
T TR4/4A Coolant in the oil - again. Triumph 18
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
P Coolant level indicator wrong? Jaguar 4
sparkydave Coolant hoses Spridgets 5
T TR4/4A Oh crud - coolant in the oil Triumph 33
W Waterless Coolant Austin Healey 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
RAC68 Waterless Coolant Austin Healey 29
B TR2/3/3A coolant expelled Triumph 14
Keith_M 1275 burning coolant Spridgets 20
S Coolant Loss Spridgets 32
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
M oil in coolant Austin Healey 16
M TR4/4A Coolant. Triumph 7
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
Keoke Waterless Coolant Austin Healey 12
S TR6 waterless coolant Triumph 6
MY66AH Coolant Leak From Fill Neck Spridgets 3
