Painting underside of front and rear shroud - Original prep and color?
blueskies
This question has to do with two projects - a 1957 100-6 BN4 and a 1963 3000 BJ7 - undergoing restoration. I'm working on the front shrouds for both and hope to get around to the rear shrouds soon. Both front shrouds required replacement of the lower front sections and various other welding repairs that are more or less done. All surfaces of the shrouds are now down to bare aluminum.
While virtually everything on the frames and inner bodies of these cars seems to have been painted body color, that does not seem to apply to the underside of the shrouds. The underside of the 1957 front shroud was finished in dull black paint, without primer underneath. I can't say for sure whether that was original paint, but it may have been. The BJ7 front shroud also had black paint on much of the underside, in addition to areas with undercoating and several other colors of paint.
Can anyone tell me how the factory finished the underside of the front (and rear) shrouds? For the front shrouds, I thought of applying an etch primer to help with paint adhesion on the aluminum and following that up with a few coats of low gloss or flat black enamel.
Keoke
Well
The most common method of detecting the original color of an unrestored car was to check up under the dash and see what color was on the underside of the shroud.
Additionally, a common practice is to paint the body parts off the car.Consequently, both sides were painted at that time.
Top Down Resto
Im going to say the shrouds were primed in black on the undersides as were some of the smaller body brackets,ect. too, the car was then primed in a reddish color before the main finish color. I have worked on many 3000s and especially the BJ8s which were done this way. The front shroud underneath should have some body color sprayed up from the adjoining super structure painting, the rear shroud was almost totally painted body color, just went and looked at my 65 original BJ8 and was this way. I will be painting the undersides of the shrouds in PPG DP90 (black epoxy primer) as it will adhere to the unsanded aand cleaned bare alum.
hope this helps
Carroll Phillips
J Painting Underside of Shrouds Austin Healey 13
timsgolf Center Dash Switch Plate Painting Austin Healey 5
LAW75 Painting the Grille Surround Austin Healey 12
J Shroud Painting ["Finally done with these"] Austin Healey 3
GeorgeC Painting the Battery Austin Healey 0
J Painting a Frame and Substructure Austin Healey 12
Jim_Gruber Bugsy IV - Painting, Cutting, Buffing is done Spridgets 20
S TR2/3/3A painting the floors of my tr3. Triumph 2
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J TR2/3/3A Painting floor pans Triumph 2
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
J TR2/3/3A Painting Triumph 11
S TR2/3/3A how to position pieces when painting Triumph 7
T TR4/4A Painting front hubs Triumph 2
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
69MGC T-Series MGTA Digital Painting 2 MG 0
B TR6 TR6 Painting/Restoration Triumph 2
69MGC MGC MGC Digital Painting MG 0
69MGC AH 3000 Digital Painting Austin Healey 0
69MGC Newest Digital Painting Aston Martin Other British Cars 0
B TR6 Painting a '74 TR6 Triumph 1
H Healey 100 Painting Austin Healey 5
KVH General Tech Questions About Painting Triumph 6
kennypinkerton General MG Rostyles. Painting question. MG 2
KVH General TR Painting the Engine Compartment with Spray Can Triumph 3
S TR2/3/3A painting the body tub “inside” Triumph 31
B Painting the Car - Corner Bead Advice Austin Healey 21
S TR2/3/3A I hate painting Triumph 8
J Final painting detail questions Austin Healey 16
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
Bob Claffie MGB Painting rubber bumpers MG 4
T TR6 Painting the car with the fenders on Triumph 7
B Final painting of all body panels - with panels on or off car? Pros and Cons? Austin Healey 7
madhouse Painting Wheel Wells of my 100-6 Austin Healey 8
drooartz General Tech Painting my Rostyle wheels MG 7
R TR4/4A Painting engine in the car Triumph 7
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Painting transmission Austin Healey 7
glemon New Painting Method Restoration & Tools 2
J Painting the car Austin Healey 8
Jim_Gruber Painting inside a BE Boot Spridgets 8
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
Brinkerhoff Painting or dyeing to change interior color? Restoration & Tools 2
D Live and learn… then learn some more… [painting] Spridgets 28
D Wheel painting frustration Spridgets 25
af3683 TR2/3/3A Painting Original Lucas TR3 Starter Triumph 3
DornTRoriginal TR2/3/3A TR3 Engine Painting Triumph 8
wangdango inner body panel painting/welding/etc Austin Healey 3
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
L Advice for cleaning/painting 1980 rubber bumpers MG 8
