General Tech Painting my Rostyle wheels
drooartz
After I got home from my morning drive it was time to paint my Rostyle wheels. Three of them were not too bad, a little rough but your basic Rostyle. The fourth was lousy yellow paint and surface rust. Not good at all.
I chose a basic silver color (Ford Argent silver if I remember correctly, it was what the local parts store had in a silver wheel paint, I wasn't too picky). I'm not a fan of the standard Rostyle paint scheme -- a bit to 70s for me. So I decided to just to a plain silver and be done with it.
Here's what I started with. One yellow and 3 silver/black wheels. Scratches, pitting, and a bit of surface rust. Otherwise they're solid wheels.
The common wisdom is that the most important part of a paint job is the prep. I'll add in that knowing what you're trying to achieve is just as important. I was only looking for a good 10' paint job, so perfection wasn't necessary or even possible with these wheels. Good enough is good enough here, and I proceeded accordingly.
I started with a wire wheel on the yellow wheel to clean it up and get some of the yellow paint off. Then I switched to sand paper to clean it up some more and rough up the surface for paint adhesion. Next was a quick wipe down with acetone to clean off any grease. While in this stage I pulled out an old toothbrush to try and scrub some of the grease, and discovered that the toothbrush/acetone combo cleaned off all the yellow paint too, leaving the original paint underneath pretty much untouched. So scrub I did, and got the majority of the yellow off. One more pass with the sand paper and all was ready for paint.
Spent a bit of extra time making sure everything was masked up carefully to keep the paint off of the tires. In a perfect world I'd have removed the tires and wheel weights before painting, but time and resources are what they are and I just had to mask off carefully. I'll have to repaint if I ever need to rebalance the wheels, but that's simple enough if it comes to that.
Paint went on in three coats, keeping things reasonably light each coat to avoid too many runs. In the end the paint went on reasonably well, certainly good enough for my needs.
And the end result, a silver Rostyle wheel. The wheel in the picture is the formerly yellow/rust wheel. Cleaned up nicely in the end. They'll certainly do well enough for a driver car, and only cost a 6-pack of beer and a few dollars for the paint. I need to find one more wheel for a spare, and I'll be ready to go. All in all, I'm happy with the results and ready to get some miles driven! :driving:
I'll give them a few days to cure up, and on the car they go. Already ordered new center caps from Moss which should be here on Wednesday -- I'll have some completed pictures after that.
PAUL161
Nice job Drew! They came up looking real nice. Now the car will looked dressed up! :encouragement: PJ
Platinum
Brother had a GT with Rostyles, We did a silver with the burgundy car color as the accent. Taping the things (all five) was the biggest PITA. Had chrome rings added, too. Looked good on the car tho.
drooartz
drooartz
They are officially good enough. They cleaned up well, and with new center caps won't take away from the look of the car, which is adequate for the job at hand. I'd love to find a set of original steel GT wheels (or get a set of the modern Dunlop-replica wheels) but there isn't budget for this car. So silver Rostyles it is.
The thought of masking all of those wheels didn't appeal to me either, Doc. Plain and simple wins the day here.
If the GT was still in the original British Racing Green I might have considered doing the accents in the same color, but the red would be a bit much for me.
drooartz
drooartz
Wheels are done and on the car. I'm satisfied with how they came out, and it's nice to just be able to take the car out for a drive.
New center caps and lug nuts clean things up nicely. Still need to find one more for a spare -- one will turn up eventually. Took the car on another drive yesterday with my local club, was nice to be driving again.
Platinum
It really looks GOOD, Drew.
R Painting Rostyle Wheels? Spridgets 11
G Painting Rostyle Wheels Spridgets 9
7 Painting Rostyle wheels?? MG 14
timsgolf Center Dash Switch Plate Painting Austin Healey 5
LAW75 Painting the Grille Surround Austin Healey 12
J Shroud Painting ["Finally done with these"] Austin Healey 3
GeorgeC Painting the Battery Austin Healey 0
J Painting Underside of Shrouds Austin Healey 13
J Painting a Frame and Substructure Austin Healey 12
Jim_Gruber Bugsy IV - Painting, Cutting, Buffing is done Spridgets 20
S TR2/3/3A painting the floors of my tr3. Triumph 2
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J TR2/3/3A Painting floor pans Triumph 2
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
J TR2/3/3A Painting Triumph 11
S TR2/3/3A how to position pieces when painting Triumph 7
T TR4/4A Painting front hubs Triumph 2
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
69MGC T-Series MGTA Digital Painting 2 MG 0
B TR6 TR6 Painting/Restoration Triumph 2
69MGC MGC MGC Digital Painting MG 0
69MGC AH 3000 Digital Painting Austin Healey 0
69MGC Newest Digital Painting Aston Martin Other British Cars 0
B TR6 Painting a '74 TR6 Triumph 1
H Healey 100 Painting Austin Healey 5
KVH General Tech Questions About Painting Triumph 6
kennypinkerton General MG Rostyles. Painting question. MG 2
KVH General TR Painting the Engine Compartment with Spray Can Triumph 3
S TR2/3/3A painting the body tub “inside” Triumph 31
B Painting the Car - Corner Bead Advice Austin Healey 21
S TR2/3/3A I hate painting Triumph 8
J Final painting detail questions Austin Healey 16
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
Bob Claffie MGB Painting rubber bumpers MG 4
T TR6 Painting the car with the fenders on Triumph 7
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
B Final painting of all body panels - with panels on or off car? Pros and Cons? Austin Healey 7
madhouse Painting Wheel Wells of my 100-6 Austin Healey 8
R TR4/4A Painting engine in the car Triumph 7
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Painting transmission Austin Healey 7
glemon New Painting Method Restoration & Tools 2
J Painting the car Austin Healey 8
Jim_Gruber Painting inside a BE Boot Spridgets 8
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
Brinkerhoff Painting or dyeing to change interior color? Restoration & Tools 2
D Live and learn… then learn some more… [painting] Spridgets 28
D Wheel painting frustration Spridgets 25
af3683 TR2/3/3A Painting Original Lucas TR3 Starter Triumph 3
DornTRoriginal TR2/3/3A TR3 Engine Painting Triumph 8
