TR2/3/3A Outer Front Wheel Bearing
CJD
I just reviewed my old pics. The new stubs I used also had the ridge...so I guess that IS the norm. I did notice that in order to pull the stub axle tight I had to use thick washers under the nut. This is against the inside of the vertical link...not under the bearing nut.
TR3driver
Great Pumpkin - R.I.P
That new stub axle has a machined ridge. That is not right and has me wondering if some processes in the manufacture were skipped on your axles. Look at the difference in the ground bearing surfaces between the old and new. The new is much more coarse than I am used to seeing.
Might well be the difference. Originals were finished all over, likely hardened, tempered and then ground to final size (to eliminate any warping from the hardening process). From the looks of it, that new stub has been turned to final size, which is more practical with modern tooling (carbide tool bits, etc) and less expensive. To further cut cost, they only machined where necessary.
But it still scares me that their CNC lathe "forgot" a step.
"Computers don't make errors. What they do, they do on purpose!" - Dale Gribble
J
Joel M
Just wanted to close this out by saying I purchased the uprated kit simply for peace of mind. I got it directly from Tony Drews for $260 including shipping. If anyone else is interested, the website is https://www.tonydrews.com/Jack_Parts.htm. The same kit costs $387 at TRF and $470 at Moss (plus shipping).
Joel
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
G excess wear on outer edge of front tires Austin Healey 13
Jim_Gruber Looking for DS Outer Rocker - Front 4" Spridgets 9
SNClocks Gap between inner and outer fenders Spridgets 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
B TR4/4A Outer tie rods Triumph 8
69MGC MGC Replacing an Outer Wheel Well panel MG 3
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
red57 What is correct wire harness outer wrap Austin Healey 17
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
F TR2/3/3A KAS-Kilmartin outer sills with bow to match door Triumph 4
Csarneson How do the outer sills [rockers] drain water? Austin Healey 7
Lukens Outer rocker showing "rust" Restoration & Tools 11
D TR2/3/3A 7.68, outer tie rod Triumph 4
B Outer steering column connection to the steering box Austin Healey 6
H General Tech Door Glass outer seals installation Triumph 6
F TR4/4A TR4 inner and outer sills Triumph 2
MisterB Outer structure repair order/checklist Austin Healey 9
S TR2/3/3A outer sill and fan tail Triumph 11
red57 Outer Sill/Rocker fit problem Austin Healey 11
T TR2/3/3A Requesting some picture of the outer Rocker panel Triumph 19
A TR2/3/3A 1959 TR3 Inner and Outer Rocker Replacement Bracing Triumph 10
M BT7 Outer Sill Replacement Austin Healey 2
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
H TR4/4A Outer door waist seal Triumph 5
britlover TR4/4A Anyone know a source for TR4-6 outer sills that actually fit? Triumph 13
S inner sills, outer sills, a post...where to start? Spridgets 28
I Sealing new outer panels on BN1 Austin Healey 10
O TR6 Outer Rockers WTB Restoration & Tools 0
O TR6 TR6 Outer Rocker Panels WTB Triumph 0
G OD of inner spring is tight to ID of outer spring Triumph 3
R TR4/4A 1966 TR4a , outer tie rod question Triumph 7
M Photos of my outer sill repair Spridgets 11
M TR2/3/3A TR3 outer sill replacement Triumph 15
hondo402000 TR6 TR6 outer sill replacement Triumph 2
germanmichel Fixing outer tube in steering box Austin Healey 11
K TR2/3/3A Paging TR3Driver re: trunnion outer washers... Triumph 4
J TR6 joining the inner and outer sills on a TR6? Triumph 1
G TR2/3/3A TR3 lower outer trunnion Triumph 4
M Outer Wheel Bearing - interference fit v Quality? Triumph 2
J TR6 Replacing TR6 Outer Rocker Panels Help Triumph 1
G Plan 9 from Outer Space Triumph 3
C How does one remove the outer door chrome? Austin Healey 2
ChrisS Steering Rack Outer Tie Rod End Size Spridgets 3
tr6web TR6 Outer tie rod question - TR6 Triumph 5
tr6web TR6 Outer tie rods - TR6 Triumph 10
A Outer sill replacement Triumph 2
tr6web Outer and inner sill [rocker] installation Triumph 5
