Noisy fuel pump
4tecdog
Season started for frogeye done a couple of runs this week to check all ok for a few events this year, noticed on a couple of occasions the facet type fuel pump makes a noisy tapping sound but it does not effect performance at all. Appears to start being noisy after about five mile run. Should I be concerned or is it just a characteristic feature of this type of pump? I have seen a few past posts on these pumps but cannot weigh up if they are reliable or not.
Gliderman8
I have the Facet in my car and YES it does make a "clicking" noise every so often.
It's annoying but the clicking does stop in short order. That's the norm for the pump... motor on!
4tecdog
4tecdog
Thanks for the reply I won't let it worry me then just turn the radio up - forgot no radio have to sing :smile:
Gliderman8
When I first installed mine the noise concerned me but I soon learned that it was just the way these pumps are.
You may want to print the warning sticker and place it in your car for passengers... just saying :grin:
Sarastro
The Facet pumps seem to be noisiest when they are not full of fuel. Today's gasoline forms vapor bubbles very easily, and I suspect you're just getting one in the pump. It goes away after it works the bubble through the pump.
I had a Facet in my Bugeye and have one now in my Porsche. I've had te same experience as you, in both cars.
SD Bugeye
Isolate it from the car.
i used two pieces of short fuel,line with washer on ether end
run bolts thru the pump mounting holes the washer fuel,line washer car body.
quites it down to near silent
4tecdog
4tecdog
May have just found one reason for my fuel pump being extra noisy went for a 30 mile ride today and ran out of fuel quarter of a mile from home! Fuel gauge reading nearly half full I'm sure the petrol fairy has drunk some of my fuel 😀
bighealeysource Noisy solid state fuel pump Austin Healey 15
R noisy fuel pump MG 6
P Noisy Fuel Pump? Triumph 0
8 Noisy differential and fuel additive questions Triumph 9
Fanch00 Noisy Side Screens Austin Healey 13
G Noisy Rear Hubs Austin Healey 6
T TR2/3/3A Noisy tachometer Triumph 9
P MGB Noisy Rear Axle / Differential MG 1
JFS TR2/3/3A Noisy Lifter Triumph 14
vickxxx TR2/3/3A new water pump noisy after 6 months Triumph 5
Bugeyze Noisy spin on oil filter Austin Healey 9
M TR2/3/3A TR3A noisy heater Triumph 6
Boink It's probably noisy on the street... Rover / Land Rover 0
H Noisy diff in BJ7 Austin Healey 2
Darrell_Walker Noisy A/C Triumph 27
JFS Noisy Lifter Triumph 3
V TR2/3/3A Noisy TR3a Engine Triumph 35
T Noisy valves a problem? Triumph 18
KVH TR4/4A TR4A Suddenly Noisy Suspension Triumph 5
T Datsun 210 - noisy? Spridgets 8
RandallRK Head gasket / noisy engine Austin Healey 13
G Noisy valvetrain Triumph 22
delisaj TR6 tr-6 noisy clutch? Triumph 7
S BJ7 Noisy Muffler Austin Healey 0
Z Noisy valve train in rebuilt motor? Plus pics... Triumph 4
Woodie noisy shifter Spridgets 23
Brosky Noisy door checks - any fix known? Triumph 5
AndreL TR6 Conversion to electric fuel pump Triumph 11
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
A TR6 How many fuel filters-TR6 Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
