Datsun 210 - noisy?
TheMidget69
My datsun 210 trasmission is starting to get really noisy or at least I think it's noisy. All the gears shift in smoothly but 2,3,5 gears seem really high pitched but 4th gear is quiet.
I haven't checked the transmission oil in sometime so maybe it might be low. But I really hope I don't have to get the the transmission pulled out and rebuilt. The PO did not have the transmission rebuilt...i wish the PO did.
So is it time for a rebuild on the transmission? eeek!
Sarastro
Hard to say. Depends on exactly how noisy it is, and what you find out when you check the oil. Do the easy things first. Not all problems are serious, but we tend to think they are at the outset.
regularman
It is normal for 4th to be the most quiet. It is not really a gear but a straight 1 to one lock of the input shaft to the output shaft. All the others have gear meshes. There is not much insulation in a midget and you are closer to the tranny than in most cars (that is why the shifter is shortened). With the top up the gear whine is more noticeable but not near so much as in the old 4 speed.
Billm
I would check the oil level really quick before you toast that thing! They are tough but not completely unbreakable!
Bill
Tullamore
You can put the oil in an empty grease gun or attach a hose to the end of the bottle and squeeze it out.
Billm
I bought one of those cheapo plastic pumps that screw into the top of an oil bottle and pump it in- really easy.
Bill
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
T Datsun 210 at Pull-N-Save Mesa, Arizona Spridgets 3
T 1982 Datsun 210 near Sacramento, since March 09 Spridgets 0
T 1982 Datsun 210 in Denver Spridgets 13
T 1981 Datsun 210 Orlando U Pull & Pay Spridgets 18
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
Rut Datsun 210 Spridgets 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
Jim_Gruber Searching for Datsun 210 Front Bellhousing from a Trashed 210 Spridgets 10
bugedd Datsun 210 Trans Question Spridgets 9
RickB Datsun 210 5 speed dogleg on Seattle Craigslist $350 -nfi Spridgets 5
RickB Datsun 210 with manual transmission $500 Spridgets 0
C 1981 Datsun 210 for $900 Spridgets 6
R WANTED : Datsun 210 5 speed gearbox Other Cars 9
6 datsun 210 5 speed rear seal won't stay in trans. Spridgets 22
bugedd Datsun 210 trans question Spridgets 33
RickB Datsun 210 on Craigslist Spridgets 5
B Datsun 210 5-speed [NFI] Spridgets 5
B Datsun 210 5-speed [NFI] Spridgets 0
RickB Datsun 210 motor and 5 speed Spridgets 6
M T9 or Datsun 210? Spridgets 15
B How to identify a Datsun 210 5-speed transmission Spridgets 1
B Datsun 210 donor Spridgets 2
RickB Datsun 210 with 5 speed on Seattle CL $500 Spridgets 19
M Datsun 210 transmission 5 speed shift lever Austin Healey 4
G Datsun 210 5 speed disassembly Spridgets 23
B Datsun 210 trans value? Spridgets 32
T Shift Levers for Datsun 210 5 speeds???? Spridgets 34
RickB Orlando CL - Datsun 210 with 1500 & 5 speed +weber Spridgets 4
RickB Datsun 210 w/5sp Seattle Craigslist [nfi] Spridgets 0
lbc_newbie Datsun 210 tranny....ventilation or missing screw? Spridgets 2
Gundy Looking for a Datsun 210 tranny Spridgets 16
RickB Datsun 210 for sale in WA [craigslist] Spridgets 3
M Datsun 210 Trans Problem Spridgets 9
B Another Datsun 210 w/5-speed in Seattle Spridgets 9
B Datsun 210 w/ 5-speed FS in Seattle Spridgets 0
mrsprite Who needs a Datsun 210 tranny? Spridgets 12
B Datsun 210 w/5-speed near Seattle Spridgets 2
M Datsun 210 Tran/Ebay Spridgets 19
msoylemez datsun 210 trans oil capacity Spridgets 4
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
Boink Datsun 2000 Spotted 5
shadowfever Datsun 5-speed info neede Spridgets 5
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
Bayless Started adapting the datsun gearbox today Spridgets 46
K TR2/3/3A Datsun 240Z aluminumn brake drums? Triumph 5
Marvin Gruber Datsun 2000 Other Cars 12
