Noisy Rear Hubs
Guy Marshall
Member
Hi all,
I am replacing the rear brake shoes on my BN6 and I notice that the rear hubs make a noise when they are turned by hand. It's not a constant noise, but more of a click, click, click as the teeth in the diff are engaging. This happens on both sides and whichever way the hubs are spun.
Is it normal?
G
Guy Marshall
Member
Thanks for the reply Bob.
Plenty of oil in the diff (maybe a little too much as there's some seepage from the rhs halfshaft) but popping out the halfshafts makes it clear - the rhs hub nut is loose and the bearing is knackered.
Happily there are extensive threads on this forum with lots of advice for replacing the bearings... What would we do without these cars to keep us busy?
bob hughes
Keep the old bearing you can use it to tap the new one in, unless you have the right tools. make sure that the new one is square to the hub and gently drift it in.
Cheers
Bob
steveg
Cheers
Bob
Bearing in the freezer; hub in the sun until it's warm - it'll tap right in.
See previous threads about cardboard gaskets being too thick, causing bearings to spin.
Keoke
P MGB Noisy Rear Axle / Differential MG 1
Fanch00 Noisy Side Screens Austin Healey 13
T TR2/3/3A Noisy tachometer Triumph 9
4tecdog Noisy fuel pump Spridgets 6
JFS TR2/3/3A Noisy Lifter Triumph 14
vickxxx TR2/3/3A new water pump noisy after 6 months Triumph 5
Bugeyze Noisy spin on oil filter Austin Healey 9
M TR2/3/3A TR3A noisy heater Triumph 6
Boink It's probably noisy on the street... Rover / Land Rover 0
H Noisy diff in BJ7 Austin Healey 2
8 Noisy differential and fuel additive questions Triumph 9
Darrell_Walker Noisy A/C Triumph 27
JFS Noisy Lifter Triumph 3
V TR2/3/3A Noisy TR3a Engine Triumph 35
bighealeysource Noisy solid state fuel pump Austin Healey 15
T Noisy valves a problem? Triumph 18
KVH TR4/4A TR4A Suddenly Noisy Suspension Triumph 5
R noisy fuel pump MG 6
T Datsun 210 - noisy? Spridgets 8
RandallRK Head gasket / noisy engine Austin Healey 13
G Noisy valvetrain Triumph 22
delisaj TR6 tr-6 noisy clutch? Triumph 7
S BJ7 Noisy Muffler Austin Healey 0
Z Noisy valve train in rebuilt motor? Plus pics... Triumph 4
Woodie noisy shifter Spridgets 23
Brosky Noisy door checks - any fix known? Triumph 5
P Noisy Fuel Pump? Triumph 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
