Noisy valvetrain
G
Since I've gotten the 6 back on the road, I notice that with the new cam (S2 from Ted Schumacher) my roller rockers are noisy as heck. I have a cast aluminum valve cover and the whole thing sounds like a cheap sewing machine. The auxillary oil feed is working fine, I have a ton of oil up there all down the line when pumping. The noise is so noticeable that it is a nuisance. I checked all my clearances after about 300 miles and nothing really moved. Set the intake at .016 and the exhaust at .018. Are these things usually that noisy? Don't remember it being that bad before. The head was rebuilt and everything in good shape.
kodanja
Turn up the stereo.....
Thanx for that info, cuz I was going to get the aluminum rockers , now I'm not so sure...
How Is the engine performing?
vettedog72
With that much gap, you can expect a LOT of noise. I don't know what your gap should be, but i know 0.016 or 0.018" is big for valve clearence. Just an opinion.
Platinum
My guess is it runs like a scalded dog. The alloy cover and the (necessary) wider clearances make for an AMPLIFIED amount of noise. You're in a "live with it or not" circumstance. A possible damping of Db could be had by going back to the original VC... less bling, but a bit lower noise level.
..."careful what you wish for"... :smirk:
TR3driver
Great Pumpkin - R.I.P
Obviously, your exhaust is not loud enough !
:jester:
You could also try putting some insulation under the hood and on the firewall, to absorb some of the noise. There was a fellow selling custom-cut foam insulation pads on eBay, but I don't see him at the moment.
Vettedog, that's no doubt the specified lash for that cam. 'Performance' camshafts almost always take more lash than the stock camshaft; since they are optimized for performance and not noise.
Andrew Mace
DrEntropy said:
My guess is it runs like a scalded dog. The alloy cover and the (necessary) wider clearances make for an AMPLIFIED amount of noise. You're in a "live with it or not" circumstance. A possible damping of Db could be had by going back to the original VC... less bling, but a bit lower noise level....
And here I'd always thought that the thicker cast alloy valve covers tended to quiet things down more than the thin stamped sheet-steel originals. Or perhaps the alloy covers are "jus' like ringin' a bell"?
TR6oldtimer
Nah, Bill's valve lash and high lift cam are causing the rockers to hit the valve cover... :laugh:
R
RonMacPherson
Query, why the external oil feed?
Roller rockers require less oil, lubrication, to operate at optimum. So with the external oil feed sounds like overkill..
70herald
I also was under the impression that they would tend to quite things down a bit. I got my nice shiny new alloy vc in the mail recently and hopefully will have get my head back tomorrow so I guess I will have to test this out. Of course since the old tin pan is so bent that oil leaks no mater what I do, the alloy vc is going to stay even if it does make noise!
John_Mc
:jester:
Have you seen the afterburners Bill has on his car? I'm figuring the valve noise must be REALLY loud to be noticeable over those!
Brosky
Bill,
My TH5 Cam from BPNW is set at .014" Intake and .018" Exhaust and it is no louder than the stock cam, which made no noise at all.
Is there any movement or excessive side play in those roller rockers?
AltaKnight
I've got the same cam and valve clearances as Paul above and mine sounds like stock also.
TR6oldtimer has a comment above about the rockers hitting the VC because of the extra lift; he might be right!
Brosky
Graham,
I missed Ray's comment. That is entirely possible with the thicker aluminum cover and a crushed cork gasket under it.
That one is easy to check when you remove the cover and look underneath.
Brosky
A lot of good thoughts here.
First question that I should have asked; does it make the noise with the cover either on or off? If it does it when off, that eliminates the arm hitting cover issue.
G
I'm in New Orleans working on my son's house. I would rather be home.
