Moving Gas Tank
tomgt6
I was thinking about how often I drive with someone in the car and the way the weight is distributed and then realized that the car was designed with the steering wheel on the right hand side but changed for the US market to the left.
So would it make sense to move the next heavy item in the car to the other side as well to help with performance. What is the next heavy item that is mounted to one side of the car? Correct that gas tank when full it quite heavy and all the weight sits on the left hand side along with the driver.
So here is my question. Would moving the tank to the other side help with balancing the car? Has anyone ever tried moving the tank?
Tom
V
vagt6
It shouldn't be that hard to do, Tom, but I have often thought that the location of the fuel tank is pretty dangerous. Let's not think of what would happen to the tank in a rear-end collision.
MOving the tank would require patching up the fuel filler neck hole on the rear valence, and cutting a new one of the other side, unless you wanted a really long filler neck and hose to the tank. Seems like a big project, maybe not worth the effort to me.
As such, one GT6 mod that was top on my list (but I never did) was a fuel cell, which could be easily located anywhere in the back.
Just rambling here, I hope it's useful!
Mickey Richaud
Great question, Tom. I've often wondered about weight distribution, and wasn't aware that the GT6 had its tank offset. The TR3 and MGB are centered, as is the battery in the TR3, and most MGB's had two 6-volt batteries, I assume for that reason.
Don't know how much effort it would be to move it, but sounds like something to consider, as long as there's room for it. Guess the other question would be whether it would be worth the trouble.
Mickey
VitSport6
Hi all.
This has been talked about with the Sports 6, The tank is on the LH side along with the driver, On Heralds and Sports 6's there is a little 1/4-3/8" spacer between the left front coil and turret...Er, uh I think thats what its called, The thought is to give it a little extra highth for the added weight on the LHS.
Sorry I dont have a part #, Its only been found in few catt.
Just a thought
Simon TR4a
Interesting idea; I don't like the notion of the gas tank beoing to one side because its weight changes depending on how much fuel is in it, affecting the balance of the car.
On the other hand probably not as much as having or not having a passenger, since gas weighs 10lbs. per imperial gallon, and its a small tank.
I would think about moving the battery might be easier.
Simon.
T
tomgt6
On the GT6 the battery is in the front on the passanger side. Being the tank holds 11 gal. and the weight of the tank I am guessing 150lbs. full. Maybe moving it to the middle would be better but I don't know about the spare then.
AngliaGT Skip Barber Racing School moving to VIR Racing 2
71TR6 TR2/3/3A Moving a radius on sheet metal patch Triumph 12
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
V Moving into New Grage TVR 8
Jim_Gruber Bugsy -Moving forward - RF Suspension is out Spridgets 3
KLUTZ FS. My '64 B, OD, Love it but moving on... MG 7
Sopwith_Camel mg guy moving up Jaguar 31
rlich8 Timing Mark Moving Around Triumph 21
D My B is moving under it's own power MG 10
boxfullofyertoys Moving sale! No reasonable offer refused! Spridgets 2
tahoe healey Moving car with out coolant Austin Healey 5
tomshobby Moving on! Spridgets 4
apbos TR2/3/3A Ideas for moving my TR3a????? Triumph 4
J fender cover out of moving pad Austin Healey 6
T OT - I'm totally bummed. FJR moving to a new home Triumph 13
theleisure Moving North, Looking for '66 Hardtop Spridgets 7
T TR6 Moving TR6 gearbox to TR4a - any issues? Triumph 5
Tinkerman TR2/3/3A Moving & Setting Body on the Frame TR3A Lifting P Triumph 10
drooartz Moving high beam switch Spridgets 13
T The "Sock Zone" is moving into my garage.... MG 1
tahoe healey Moss moving? Austin Healey 12
eejay56 Spitfire Help moving a Spit in Salem Triumph 13
mrstinson Moving and need help Spridgets 8
Trevor Jessie Moving wiper motor Spridgets 6
tahoe healey Dixon is moving! Austin Healey 14
toysrrus toysrus [Russ] is moving to the Jaguar Section Triumph 23
beaulieu moving a car cross-country - by furniture movers? Restoration & Tools 16
I TR6 69 TR6 static vs moving timing - what is better? Triumph 6
K TR2/3/3A TR3...Moving the Coil & Petronix Wires Triumph 3
T TR6 TR6 died - moving plate earth lead fired Triumph 15
JFS Moving Tool Chest Restoration & Tools 5
kyreb1862 MGB Moving an MGB MG 26
S Car moving/transport company suggestions? Other Cars 20
drooartz Moving on to the generator Spridgets 32
zimmy car is jerky when moving Spridgets 4
soren_ak question regarding moving a car from England to DK Austin Healey 2
Stewart Moving around an MG MG 6
T GT6 moving the body on a gt6 Triumph 4
kindofblue TR5/TR250 TR250 Latest - Moving Ahead Triumph 16
S MGB mgb roadster : sticking the hood to the rear moving bar of the cage MG 12
Celtic 77 MGB LeMans Gas filler MG 10
mctriumph General TR NEVER start a car with stale gas Triumph 0
TomMull GT6 Gas Tank Outlet Triumph 0
B TR6 Gas on spark plugs Triumph 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
Celtic 77 MGB Pessimistic Gas gague MG 10
