Moving on to the generator
drooartz
So after I got my car started last night I went on a little spin through my town. It was dusk, so I had the headights on. After maybe 20 minutes or so of driving about I noticed that the ignition light was on. Turning off the headlights didn't seem to help, nor did revving up the engine a bit. I did notice when I first started the car that the light didn't go out right away. A quick blip of the throttle seemed to make it turn off, though.
I'm going to run through the generator tests listed in the shop manual tonight, but does anyone else have any good tests to run? I figure to also test the battery and make sure it is in good shape.
Also, does anyone know what sort of grease to put in the little "oiler" dohickey on the early style generator? Manual says to use a "high melting point grease"--is this the same as I will use to grease the various zerks on the chassis?
Kurtis
Drew,
Check all your connections first (generator to control box, etc.). I know on my car, things are pretty tight, and I've knocked the wire loose from the generator to the control box while messing around with something else on that side (like the distributor). I usually don't notice it until I start the car up and see the ignition light stay on.
Platinum
The charge problem will likely be the brushes and/or the commutator. Generator brushes are a cheap, easy fix. Use red ScotchBrite to polish up the commutator, put in a new set of brushes and Tunebug will be happy again.
As for the grease, I'd say LubriPlate, but best to get other opinions.
EDIT: WallyMart carries Castrol "Marine Bearing Grease" in tubes on the shelf... that'd also be a good one.
Deleted member 3577
You should have a 2 bobbin control box.
Try cleaning the contact points on the left (voltage regulator) relay.
Use tuner cleaner and glass paper.
Sometimes that does the trick.
Platinum
Control box... good thing you guys are payin' attention. I sure wasn't. /ubbthreads/images/graemlins/tongue.gif
Deleted member 3577
Yes the famous Lucas control box.......
The only thing less reliable than the Lucas flasher relay.
I'm often checking over my shoulder to verify blinky-blinky.
And I watch my ammeter like its the coolant temp gage at a nuclear power plant. /ubbthreads/images/graemlins/grin.gif
drooartz
drooartz
[ QUOTE ]
[/ QUOTE ]
Showing my ignorance once again--what would these 2 items be? Glass paper I assume is some sort of sand paper, but tune cleaner?
Thanks all for the suggestions. I'll have plenty to look at when I get home after work.
piman
Hello droo,
glasspaper is what carpenters use to sand woodwork. Normal engineering abrasive cloths and papers are not really suitable for electrical maintenance as the abrasive gets into the works.
Alec
Morris
I know everyone may think I am a sacrelige, but why not chunk that generator and get you a nice, off the shelf alternator.
Generators suck.
Deleted member 3577
Try just the tuner cleaner first.
It can be purchased at a store that services electronics.
(Radio Shack tuner cleaner sucks)
Or you could use Automotive electrical motor cleaner.
And ask the guys at Napa if they have any points cleaning paper (1000 grit or finer)
they're quaint... like a bugeye.
I, however, have switched to an alternator since I drive a midget. /ubbthreads/images/graemlins/wink.gif
Deleted member 3577
[ QUOTE ]
Generators suck.
[/ QUOTE ]
Yes but....Can you fix your alternator roadside, with a rock & a stick? /ubbthreads/images/graemlins/grin.gif
Platinum
To the contrary, Morris: They're nearly infintely renewable! Bearings are about six bucks, brushes about the same. If it fries due to a problem upstream it'd be nasty but I'll live with the "danger". I've a rebuild "kit" inna glovebox!
I think you mistook the smogpump for the generator makin' that sucking sound. /ubbthreads/images/graemlins/jester.gif /ubbthreads/images/graemlins/devilgrin.gif
drooartz
drooartz
I'm strangely happy that my car still has the generator and + ground. If nothing else, it makes it easy to use the factory manuals/diagrams since everything still matches up. As long as the car charges, I'm happy. I've no plans to run anything but the basic electrical stuff (lights, gauges, engine, etc.--no radio or other extras) so don't need the extra output of an alternator. Fussing with this old, funky stuff is part of the fun for me. I'm working towards reliability, but I expect it to take a while. Always some little bit to sort out, especially at the beginning.
Heck, I've still got a 948 and drum brakes. Just part of the charm for me. Now I could see some day building a hot box Sprite with a 1275, 5-speed, supercharger, discs... /ubbthreads/images/graemlins/grin.gif
Platinum
Just find a "needy" Lotus Elan and save a lot of grief!
Elans used to be called: "Super Spridgets!"
EDIT: Well, mebbe a little "less grief."
drooartz
drooartz
When it comes right down to it, one old car is just about the right amount of tinkering for me. I'd get confused with more than one! A speedy LBC would be fun, but I won't give up the Tunebug, or my hopefully-soon-to-be motorcycle. So I'll just keep puttering away on what I have and be happy for it.
drooartz
drooartz
... although, if I someone handed me an Elan, or a Caterham Seven, or an original Mini Cooper S, I wouldn't turn it away! /ubbthreads/images/graemlins/grin.gif
Platinum
mehheh... well, I've the willpower of a RAT, so one of ~anything~ is about like an appetizer to someone starving... Just ain't enuff THERE somehow. /ubbthreads/images/graemlins/grin.gif
Deleted member 3577
I'm seriously thinking Europa.....
It would be a luxury car next to the Elva....Heat,weather-resistance & even a dome light.....WOW
Got to get rid of the DeLo first.....Only have space for 2 cars in the garage.
GB1
Sadly, garage space never hindered me, I see it, I want it, I buy it.
Then I look like the guy in the Home Depot parking lot who is driving a Maxima with 10 60lb bags of cement and 20 2x4x10's.
duh
AngliaGT Skip Barber Racing School moving to VIR Racing 2
71TR6 TR2/3/3A Moving a radius on sheet metal patch Triumph 12
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
V Moving into New Grage TVR 8
Jim_Gruber Bugsy -Moving forward - RF Suspension is out Spridgets 3
KLUTZ FS. My '64 B, OD, Love it but moving on... MG 7
Sopwith_Camel mg guy moving up Jaguar 31
rlich8 Timing Mark Moving Around Triumph 21
D My B is moving under it's own power MG 10
boxfullofyertoys Moving sale! No reasonable offer refused! Spridgets 2
tahoe healey Moving car with out coolant Austin Healey 5
tomshobby Moving on! Spridgets 4
apbos TR2/3/3A Ideas for moving my TR3a????? Triumph 4
J fender cover out of moving pad Austin Healey 6
T OT - I'm totally bummed. FJR moving to a new home Triumph 13
theleisure Moving North, Looking for '66 Hardtop Spridgets 7
T TR6 Moving TR6 gearbox to TR4a - any issues? Triumph 5
Tinkerman TR2/3/3A Moving & Setting Body on the Frame TR3A Lifting P Triumph 10
drooartz Moving high beam switch Spridgets 13
T The "Sock Zone" is moving into my garage.... MG 1
tahoe healey Moss moving? Austin Healey 12
eejay56 Spitfire Help moving a Spit in Salem Triumph 13
mrstinson Moving and need help Spridgets 8
Trevor Jessie Moving wiper motor Spridgets 6
tahoe healey Dixon is moving! Austin Healey 14
toysrrus toysrus [Russ] is moving to the Jaguar Section Triumph 23
beaulieu moving a car cross-country - by furniture movers? Restoration & Tools 16
I TR6 69 TR6 static vs moving timing - what is better? Triumph 6
K TR2/3/3A TR3...Moving the Coil & Petronix Wires Triumph 3
T TR6 TR6 died - moving plate earth lead fired Triumph 15
JFS Moving Tool Chest Restoration & Tools 5
kyreb1862 MGB Moving an MGB MG 26
S Car moving/transport company suggestions? Other Cars 20
zimmy car is jerky when moving Spridgets 4
soren_ak question regarding moving a car from England to DK Austin Healey 2
Stewart Moving around an MG MG 6
T GT6 moving the body on a gt6 Triumph 4
kindofblue TR5/TR250 TR250 Latest - Moving Ahead Triumph 16
T Moving Gas Tank Triumph 5
S MGB mgb roadster : sticking the hood to the rear moving bar of the cage MG 12
MGTF1250Dave T-Series Lucas Generator MG 1
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
T Spitfire MK2 Generator Triumph 3
W Generator and Starter Long Bolts Spridgets 0
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
B Generator Parts Austin Healey 6
P BN4 Generator Woes Austin Healey 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
