MGB mgb roadster : sticking the hood to the rear moving bar of the cage
shippo
Anyone know of anything good to stick that back moving bar to the hood of the car on an MGB roadter 1972. Mine keeps coming unglued.
what about superglue, or will that melt the hood??
excuse my rubbish terminology
S
shippo
hey thanks dude, but thats what Ive got on it at the moment, and I dont think much of it. When the roof gets hot in the sun, it just warms the glue, and it melts to the point where it comes apart.
any other suiggestions???
Administrator
Boss
Might try JB Weld (The stuff Paul Harvey is always talking abouyt on the radio - at least over here in the States).
Welcome to the forum!
G
JB weld will end up rigid and will break. I used contact cement and had no problems
Dave Russell
Yoda - R.I.P
Contact cement is an adhesive which bonds upon contact. The two surfaces to be bonded are separately coated with the cement & allowed to dry. When the two coated surfaces are pressed together there is an instant permanent bond. I find that the solvent based cements work better than the water based product.
It is a very common adhesive & I would expect it to be available world wide. Possibly under different names but the same idea applies.
Bruce74B
Actually, most interior adhesives and contact cements will deteriorate with the heat...a better solution to try would be a "headliner adhesive" designed to take the heat of a hood in the sun. I don't know if you have it there and I have only seen it locally in a spray can, so I can't offer to ship you some...but I bet there is some available somewhere over there.
Bruce
A
aerog
I saw a new hood on a car recently that had the fabric held to the bar with velcro (if we're talking about the bar that sits just in front of the rear window that is). Originally the fabric in that area was wrapped around the bar and glued I think - on this hood/top it was wrapped then velcroed to itself. Seemed to work pretty well.
orange02SS
Member
Try some 3M 5200 marine adhesive. Best stuff i ever used. It stays flexible and soft also. I used to use it to reglue engine mounts on jet skis.
Brakedwell
Use Evostick Contact Adhesive (In a red tube or tin). The hood should not be glued to the frame. Run a line of adhesive along each flap and join them to form a tube around the frame crossmember. The hardest part of the job is keeping glue off the rest of the hood/window/car/carpet/seats.
Good luck
I MGB Purchase of 1972 MGB Roadster MG 3
R MGB MGB Roadster Door Panel Speakers MG 9
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
C MGB 1980 MGB Roadster Tyres UK MG 0
6 Seeking 1967 MGB roadster in good driving condition MG Classifieds 3
bcliff MGB Are you looking for and MGB Roadster or maybe something else. MG 5
bcliff For Sale 1970 MGB Roadster and other British cars for sale MG Classifieds 0
David Townsend MGB 1975-80 MGB Roadster Fine Art Prints MG 0
SeldomSeen MGB Floor Mats for a '66 MGB Roadster MG 3
jackq MGB Found MGB roadster with a/c..owner wants it gone MG 0
DrEntropy MGB 1976 MGB Roadster for a patient. MG 2
M MGB 1970 MGB roadster wiring harness question MG 0
K T-Series Trailer Hitch for 1974 MGB Roadster MG 4
D MGB 1980 MGB Roadster . . . Restoration Progress MG 32
RickB MGB 67 MGB roadster project in Idaho MG 2
martyc MGB Replacement Radio Suggestions for 73 MGB Roadster? MG 23
G MGB MGB Roadster or MG Midget MG 45
D MGB 72 MGB Roadster Electrical Woes MG 19
69MGC MGB MGB Roadster Fender Replacement MG 7
703MGB MGB Tire size for MGB roadster 73 MG 12
bcliff MGB 68 MGB Roadster for sale MG 2
B MGB 72 MGB Roadster MG 6
EMGEBE MGB 69 MGB Roadster MG 3
S MGB Flared Wheel Arches - MGB Roadster MG 7
K MGB where can i buy mirror for a MGB Roadster 1971 ?? MG 3
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 0
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
