• NOTICE: This "Forum Navigation Questions" forum is only for asking questions related to navigating this web site. DO NOT post car-related questions here., For car-related questions, use the appropriate marque-related forum.
Login problem need help
Bayless
Basil,
Since last Friday I have not been able to get BCF. For years I have just used britishcarforum.com and it worked fine. Last week you had me clear cookies to get the secure server and that worked. I also used https://britishcarforum.com and that worked. Since Friday, either one just gives me a blank screen. I was starting to exhibit severe withdrawal symptoms. Today I finally tried a google search for the forum and clicked one of the links. Using https://britishcarforum.com/bcf/content.php I can finally get in. what has gone wrong and how can I fix it? That is a awful lot to type into the location bar without making a mistake.
Bayless
Administrator
Boss
This is weird. You should be able to just type in britishcarforum.com and it should re-direct to https://.... I'm going to need to do some more troubleshooting.
NutmegCT
Basil,
Bayless
Why not go to the link you show above, ( Using https://britishcarforum.com/bcf/content.php I can finally get in.) then just bookmark the page it takes you to? Then you don't have to type it again.
Tom M.
Bayless
Bayless
Basil, whatever it was, either you fixed it or it fixed itself. Today it works like it always did. Tom, I don't usually use bookmarks cause there are only a few places I visit and that is just one more step. I let firefox remember and usually can get there by just entering the first letter. It takes firefox a while to learn a new entry. Anyway, it works now. Thanks guys.
Administrator
Boss
I hope it's fixed. I did some fiddling with the redirect settings which I hope have solved the issues.
Bayless
Bayless
Still seems fine so I think you got it. That's why you get the beg bucks Boss.
Bayless
Bayless
Oops, another typo :eeek::popworm:
martx-5 Problem With Login FORUM Navigation Questions 2
mgedit TR2/3/3A Login Triumph 5
ddrumman Login name vs. display/username name. MG 22
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
KVH General TR Transmission Problem Triumph 3
DrEntropy W123 Benz recurring problem Other Cars 16
J MGB Idle problem MG 4
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
Got_All_4 TR6 Throw Out Bearing Fork Problem Triumph 7
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
E MGB MGB heater motor problem MG 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T TR2/3/3A Help - Cooling system problem Triumph 7
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
T General TR Cluthch problem / challenge Triumph 4
M Europa turn signal problem Lotus 7
T TR2/3/3A TR3A clutch problem Triumph 15
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
S Engine or Tachometer Odd Problem Austin Healey 7
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
G windscreen problem Spridgets 1
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
J TR6 72 TR6 starter problem Triumph 10
nichola TR6 New harness installed but have a purple problem Triumph 12
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
C TR2/3/3A TR3 Gearbox Problem Triumph 10
Healey Nut Clutch problem Austin Healey 5
R TR2/3/3A Tr-2 Clutch Problem Triumph 46
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
R TR2/3/3A Grounding problem Triumph 21
P TR6 Wiring problem Triumph 50
P TR6 Clutch problem not solved Triumph 6
D Acceleration Problem Austin Healey 4
