Leaf Spring Re-Arc fixture
aeronca65t
Here's a tool I built a while back, but just got to use today.
When I needed to re-arc the leaf springs in the race-Spridget (to lower it) it about 7 or 8 years ago, I used a two pound sledge hammer and "worked" them down cold. This is a time-consuming but perfectly legitimate way to change the arc on leaf springs. Also, I had read that Roger Williams used this same method with success. He's the Texas guy who started the "Spec-Sprite" class. By the way, technically, he's a member here("Jolly Roger").
The "anvil" I used was an old 1500 Spitfire engine block. I placed a spring over one of the open bores and hammered the arc back flatter (a little at a time). Once I got all the leafs on one side flattened and put together, I tried them on the car to judge how high the car sat. It took 3 or 4 attempts before I got things decent. Then I used those leafs as a template for the leafs on the other side.
Anyway, all that hammering gets <span style="text-decoration: underline">old</span> quickly, so I built this little setup to re-arc the leaf springs on the A35. I also want to re-arc the springs on the MGB and I might change the springs on the race-Spridget too. So this will see some use in 2010 for sure. When bending, I stay away from the center hole and just bend back the outer half of each leaf. I mark the spring in 1" increments and bend a little at a time. It's not a quick job, but it's easy to control and it works great.
The bottle jack is a 6 ton unit ($25 at Walmart) and the other stuff is just scrap I had around. (normally I put a piece of softwood between the spring and the ram of the jack, but I left it out for the photos).
JPSmit
And this month's McGyver award goes to...
great idea!
TR3driver
Great Pumpkin - R.I.P
FWIW, you could do the same thing with my shop press, which is somewhat similar to
Just lay the spring crosswise over the opening in the adjustable rails, and bring the ram down on them. In fact, I was doing something similar just the other day, adjusting a sway bar that had been distorted in a wreck.
G
Bet it works better on walnuts,too,than ones'forehead. Good idea.
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
F TR2/3/3A Leaf spring advice Triumph 16
Editor_Reid Unusual Leaf Spring Austin Healey 4
B Leaf Spring Re-build Options? Other British Cars 2
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
KVH General TR What Happened to My Leaf Spring's Nyloc Nuts? Take a Look . . . Triumph 17
B BJ8 leaf spring Austin Healey 2
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
S Any recent experiences with rear leaf spring vendors? Austin Healey 31
K TR2/3/3A Leaf Spring "rebound clip" thickness .... Triumph 16
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
K TR2/3/3A Leaf Spring height and front spring pin removal again? Triumph 1
C Leaf spring length Austin Healey 4
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
T TR2/3/3A Leaf Spring "Silent Bloc" Triumph 3
stuntflyr Leaf spring toe-in modification viability Austin Healey 19
H rear leaf spring to chassis bushing Austin Healey 11
simon1966 Leaf Spring Refurbishment 100 BN1 Austin Healey 3
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
DornTRoriginal TR2/3/3A Rear Axle & Leaf Spring Installation Questions Triumph 3
D Bugeye leaf-spring removal Spridgets 2
TulsaFred Leaf spring restoration Spridgets 9
RCarr removing a leaf spring Austin Healey 7
R Rear Leaf Spring Removal Triumph 10
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
Willie_P Newbie HELP: TR 3/4 leaf spring/axle installation Triumph 11
RAC68 Adding a Leaf to my Spring Leafs this Fall Austin Healey 15
K TR2/3/3A TR3 Rear Leaf Spring Shackle Bushes Upgrade Triumph 14
K TR2/3/3A TR3 Rear Leaf Spring Front Pin Removal Triumph 17
richberman how to: leaf spring bushing replacement Austin Healey 13
M need help new threaad 1/4 leaf spring Spridgets 6
PatGalvin TR2/3/3A TR3 Leaf Spring Rebuild - low friction tape? Triumph 9
T Two quick leaf spring and bushing questions Spridgets 9
Tabcon Rear leaf spring bush size? Triumph 21
tahoe healey iron bushing removal rear leaf spring Austin Healey 6
tahoe healey leaf spring direction Austin Healey 8
tahoe healey leaf spring instaltion Austin Healey 14
prb51 leaf spring squeek Triumph 10
N Rear leaf spring brackets Austin Healey 9
T MGB-GT what is the length of mgb leaf spring,pin to pin MG 2
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
1965_MGB Leaf Spring Repair? [SFL] MG 6
Atrus Leaf Spring Front Bushing question Spridgets 6
Stig TR2/3/3A TR3 leaf spring maintenance Triumph 4
