Atrus
I'm putting the red Moss poly bushings in. Stock, on the rear leafs, in the front eye of the springs the bushings surrounded a metal sleeve (where the bolt passes through), and then the bushings were within a thin metal sleeve that went into the spring's "eye".
The poly bushings have the inner sleeve - i.e., the one that the bushing surrounds and the bolt goes through. I don't have the thin "outer" sleeve that surrounds the bushing within the spring's "eye". It was destroyed during removal. So, the bushings will be just sitting inside of the spring's "eye".
Is this OK? Is this how they are supposed to be? I don't see that sleeve anywhere in the Moss catalog.
Thanks!
Thanks!
