Hydraulics -- Rebuild or Buy New?
Hatman
One of my winter projects is to completely go through the brake and clutch systems on my 1959 TR3. My question is this: should I have my original parts rebuilt by a firm like Apple Hyrdraulics (suggestions of other firms welcome) or simply buy new parts from the Big Three? My original thought was to have them rebuilt, but looking at prices, it appears I can buy new parts for the same money.
Thoughts?
Mark
TR3driver
Great Pumpkin - R.I.P
IMO, you should start by disassembling them yourself. If the bores are OK, you can install new seals yourself for almost nothing. These are very simple units (much simpler than the dual master on the TR6). The calipers can almost certainly be rebuilt (since for those, the bores don't matter), the other components are more iffy.
If the clutch & rear brake slave bores are bad, just replace them. But if the MCs are bad, keep in mind that new ones look different than the originals and make your own decision. The resleeved units from Apple will likely last longer than originals (although that's usually not an issue since it's neglect that ruins them in the first place).
RobT
IMHO if the components are original Girling, re-build them. The quality of the replacements is not nearly as good as the originals, and my experience with Apple has been excellent. (The only exception I would make is the rear brake slaves, and perhaps the clutch slaves - these are so much cheaper than rebuilds, but others may disagree).
G
When you get them rebuilt you should have them sleeved. IMHO, this is a better setup than new. I sent my new clutch master and slave off to Apple and had them sleeved. From TRF they lasted about 5k miles before they leaked. Sleeving old or new is better than better than new.
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Sleeving old or new is better than better than new.[/QUOTE]
That's exactly why I'm keeping all of my take-off parts.
PeterK
Since you mentioned this is for a TR3, the new replacement master cylnders for brake and clutch on new units is at a different angle than the originals. They come with an adapter but still not 100% original copy.
I've found with all parts that if they can be rebuilt, they will generally be a better part than new in the long run. Not all cases but most. A lot of the repro stuff is just not the same quality or materials. Close but no cigar (as Clinton would say!)
Apple did my shocks but I had a master sleeved and rebuilt by https://www.whitepost.com/brake.html who as also very good.
MGTF1250Dave
I'll second Randall and Peter, the TR3 components are easy to rebuild (later model LBC brake parts seem to be harder for the home garage to rebuild). The newer replacement master cylinders are different and replacing them will require an adjustment to the outlet piping. It is minor, but the pipes will need to be bent to fit. The rebuild kits are inexpensive and changing out the seals is straight forward. An inexpensive brake hone and an electric drill will clean up minor pitting in the bores of the master or wheel cylinders.
Replacing all of the flexible hydraulic lines should also be a consideration, particularly if you don't know how old they are. They tend to breakdown internally.
If the front disc brake pistons are pitted, replacing them with new one should also be done. IMHO you should consider upgrading to stainless steel pistons.
In the case of sever pitting in cylinder bores, the sleeve insert is an option to maintain original appearance. Apple Hydraulics, White Post Restorations and Karp's Brake Service are companies that provide the service. I would recommend discussing prices and what you want with each of them first before sending your parts out. In some case you get your parts return, in others you get finished piece in inventory and your go on the line for sleeve inserts. Most offer brass sleeves but some also offer stainless steel.
TR3driver
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif Although I try to resist the tendency towards shipwright's disease; replacing the hard lines might not be a bad idea either. I've already wrecked one TR3A (almost 30 years ago) due to a hard line rotting through from the inside. And the other day I was rooting through my box of brake spares, and was totally amazed when a moderate tug on an original brake line broke it in two ! This was one of the jumpers from the reservoir to the MC, so it wouldn't see pressure in service ... but it showed no signs of any damage or corrosion, and just snapped off in my hand.
Anyone know who has the best price on some Cunifer lines for a TR3 with Girling brakes ?
DNK
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gifGoing to buy SS lines to replace the whole set up on the 6
Brosky
That's what I just did. /bcforum/images/%%GRAEMLIN_URL%%/iagree.gif
H
Hatman
Thanks for the feedback, everyone. I was leaning towards having my originals rebuilt, since I like to stick to repairing/rebuilding the original parts whenever possible, but it's good to hear it from the group. And I am planning on replacing everything in both systems. I'm pretty sure everything is original -- it's at least 20 years old, as I've owned the car for that long -- so it seems like a top to bottom overhaul of these important systems is overdue.
Mark
SunbeamTom Clutch hydraulics rebuild Sunbeam (Rootes) 2
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
R Clutch Hydraulics Spridgets 4
P TR6 Clutch hydraulics Triumph 6
F TR2/3/3A Bleeding Hydraulics Triumph 9
ckeithjordan TR2/3/3A Apple Hydraulics vs White Post Restoration Triumph 13
D TR2/3/3A Carb work by Apple Hydraulics Triumph 2
AngliaGT For Sale TWO Apple Hydraulics Gift Certificates Jaguar Classifieds 1
TR3MT TR2/3/3A Clutch Hydraulics II Triumph 8
S TR6 life of TR6 hydraulics Triumph 5
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
Lukens TR2/3/3A Clutch hydraulics ? Triumph 8
Lukens TR2/3/3A More questions concerning clutch hydraulics Triumph 9
sundown TR6 1973 TR6 hydraulics Triumph 1
JPSmit Trivia question - clutch hydraulics Spridgets 16
PatGalvin TR2/3/3A 5-way valve, brake hydraulics Triumph 4
Rut Brake hydraulics Spridgets 3
Kleykamp clutch hydraulics ??? Triumph 8
John_Mc Clutch hydraulics-to hone, or not to hone? Triumph 14
drooartz Hydraulics or Engine first? Spridgets 18
T Apple Hydraulics for M/C re-sleeve Triumph 11
drooartz RHD vs LHD hydraulics Spridgets 2
testaj Apple Hydraulics Shocks MG 10
Steve P. Brit vs. American hydraulics Spridgets 10
Nunyas T-Series Sloooooowwwww leak in Clutch hydraulics MG 38
danielnorton After Marke slave cylinder for clutch hydraulics? Spridgets 20
Brosky Silicone vs Dot 4/5 in new CLUTCH hydraulics? Triumph 17
MGTF1250Dave TR2/3/3A TR3A Clutch Hydraulics Triumph 8
J TR4/4A TR4A clutch hydraulics Triumph 2
zimmy bleeding new clutch hydraulics Spridgets 19
Carlbanan56 MGB MGB rear break rebuild MG 6
6 Master Cylinder Rebuild Spridgets 6
wangdango Carb Rebuild Necessity Austin Healey 3
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
drooartz MGB Front suspension rebuild is next MG 57
KVH General Tech Rebuild Report Triumph 6
KVH General Tech Initial Start Up After Rebuild Triumph 23
KVH General Tech More Engine Rebuild Questions Triumph 15
G MGB '71 MGB Front End Rebuild MG 2
drooartz MGB A nice milestone since the rebuild MG 3
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
I Bugeye valve rebuild suggestions Spridgets 8
D MGB 25D dizzy rebuild MG 29
R Rib Case rebuild... Spridgets 5
K TR2/3/3A Further to brake caliper rebuild.... Triumph 2
woolfman C39 vs C40 Dynamo rebuild/parts Spridgets 0
