TR6 Clutch hydraulics
pdplot
Will be replacing master & slave cylinders and flex line. Question - it would seem better to replace the slave and flex line first before the M/C. Is that the best procedure? The clevis pin in the pedal is also worn and must be replaced as well. That explains the noise when I press the pedal - not every time but enough. I'll try the local hardware store.
steveg
Don't think the order would make a difference.
The only thing you're keeping is the hard pipe. Drain out all the fluid, then detach the slave, flex line and master. Blow the line out with brake cleaner, then compressed air. Then install your new parts, fill up the juice and bleed.
I like to pull all the fluid out of the reservoir with a plastic syringe, then only deal with the fluid in the system.
RJS
Agreed with the above. Only other comments I would add are 1) be sure you get the correct original bore diameters on the Clutch MC and SC. I suffered with a clutch which acted like an "on-off" switch for many years until I realized another mechanic installed the wrong diameter slave cylinder. HUGE difference getting the correct one in there and really made driving the car much more enjoyable.
Also, the worn clevis pin can make a huge difference in clutch feel. My clutch engagement was "floating" - high one day - low the next. No idea what was going on. Then, for unrelated reason this summer I replaced the clutch MC hardware (incl new clevis) and as a collateral benefit the "floating" clutch engagement disappeared. I will say, the clevis pin had 8,000 miles on it and probably overdue.
Bob
P
pdplot
Something happened today I still don't believe. I bought a new clevis pin (1.89) from my local Ace Hardware store but stupidly carried it out to the car in the MC rod. You guessed it - I heard it fall out as I got into the Subaru. I searched in vain outside and inside the car How could it disappear like that? Then I saw it. It had somehow impossibly fallen between the A pillar door jamb and the trim strip. The head had stopped it from falling in. I confidently reached for it and...it somehow fell into the opening, which had to be about 7/16 wide. Unless the trim strip comes off, it will be forever lost in there. I had to buy another one. Moral - put all small parts in your pocket but make sure it has no holes.
Madflyer
There is an unwritten law dropped items will always land at the location most out of reach. As for the pin I made mine from a 1/4 inch shoulder bolt that I cut off all threads and drilled for cotter pin. To the point FYI Slave cyl early TR's were 3/4 inch MC and 3/4 inch slave. It was latter changed to 1 inch MC and 3/4 inch slave. Reason was fluid moves between cylinders at one to one. Example move MC one inch and slave cyl goes one inch ( 3/4 to 3/4 ) but with one inch MC, slave goes 1 1/4 inch. Moves bearing more and easy shifting. I think these changes were made in early TR 4's. Madflyer
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
R Clutch Hydraulics Spridgets 4
TR3MT TR2/3/3A Clutch Hydraulics II Triumph 8
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
Lukens TR2/3/3A Clutch hydraulics ? Triumph 8
Lukens TR2/3/3A More questions concerning clutch hydraulics Triumph 9
JPSmit Trivia question - clutch hydraulics Spridgets 16
Kleykamp clutch hydraulics ??? Triumph 8
John_Mc Clutch hydraulics-to hone, or not to hone? Triumph 14
Nunyas T-Series Sloooooowwwww leak in Clutch hydraulics MG 38
SunbeamTom Clutch hydraulics rebuild Sunbeam (Rootes) 2
danielnorton After Marke slave cylinder for clutch hydraulics? Spridgets 20
Brosky Silicone vs Dot 4/5 in new CLUTCH hydraulics? Triumph 17
MGTF1250Dave TR2/3/3A TR3A Clutch Hydraulics Triumph 8
J TR4/4A TR4A clutch hydraulics Triumph 2
zimmy bleeding new clutch hydraulics Spridgets 19
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
