TR2/3/3A Clutch hydraulics ?
Lukens
Getting aggravated.
Should not the return spring on the slave pull the plunger all the way to it's fully retracted position?
When I adjust the slave pushrod with a little clearance and work the clutch, the clearance is disappears. Run the rod in the clevis to achieve more clearance, work the clutch, and that clearance is gone. I can keep doing this until all the adjustment on the rod is gone, and the plunger just creeps further and further away from fully retracted. However, I can force the plunger home with my hand.
I'm considering a longer, stiffer, spring. (Aren't we all? lol)
Russ
Geo Hahn
Have you tried omitting the spring altogether? As I mentioned in the other thread -- that is the only way mine will work.
I probably have a broken pin that engages itself to disengage the clutch but allows the fork & operating arm to return to far if the spring is in place.
I omit the spring as a stop-gap fix until the day when I need to take the gearbox out -- but that day is a long time coming (so far).
TR3driver
Great Pumpkin - R.I.P
Yes, the idea is that the return spring should be strong enough to always bottom the piston in the slave cylinder.
However, for that to happen, the master cylinder has to open the 'foot' valve to allow fluid to flow back into the reservoir. You might check to be sure that is happening. Eg the pedal returns all the way under just the influence of it's return spring, and there is some free play in the MC pushrod when it does. I have also had the spring inside the MC break (4 pieces by the time I figured out the problem), which was causing the piston to not return fully.
Also, the slave spring is a special, very strong spring. Lots of people try to substitute some other spring (like a screen door spring) with disappointing results. I've also managed to ruin a few slave return springs by over-stretching (probably when I had a broken taper pin).
Lukens
Lukens
I must be dense... humor me here.
Let's take the clutch operating arm out of the picture all together... disconnect it and the external spring. The clutch pedal is up. The MC has it's own internal spring that has pushed it's plunger (piston) all the way to the end of it's stoke. When in this position, the slave piston would be fully "retracted"... deep in it's bore. Now if I push the clutch pedal, juice will force the slave piston out. If I relax the pedal, the spring in the master will push it's piston back to it's free position. This will draw the slave piston back into it's retracted position. Unless I'm really, really missing something, this is pretty simple?
Now let's connect the operating arm. The external slave spring is going to keep the slave's rod tight against it's piston. Am I right so far? If this is the case, how will I establish the recommended clearance (.010) between the two.
Like I said, humor me.
Geo Hahn
....The external slave spring is going to keep the slave's rod tight against it's piston. Am I right so far? If this is the case, how will I establish the recommended clearance (.010) between the two...
I think the clearance is at the other end of the rod -- that is, it is the freeplay before the rod begins to move the operating arm. It is my understanding that this assures that the TOB isn't riding on the fingers the whole time.
TR3driver
With the slave return spring connected, you aren't going to "see" the free play at all. The spring pulls the arm and pushrod back against the piston hard enough to push the piston all the way into the slave cylinder. Ignoring any slop in the clevis, all of the freeplay normally winds up being between the TOB & pressure plate levers.
So, to set the free play (which is supposed to be much larger than .010" at the slave, more like .100" depending on which source you believe), you have to move the arm until the TOB presses tightly against the PP levers. The most straightforward way to do this is to temporarily remove the spring and then reinstall it later.
But, it's easier to just grab the lever and see how far you can pull it away from the slave against the tension of the spring. It does take a certain amount of strength to fight the spring, so if you are not strong enough, you may need to find some way to increase the leverage (or just do it with the spring disconnected). I usually just "eyeball" the adjustment, as long as it is somewhere between 1/16" and 1/8", the clutch seems to work fine for me. My feeling is that the given specification is somewhat larger than actually required, in order to allow for clutch wear before the next adjustment.
If you want a more accurate measurement (or to make the adjustment), then loosen the locknut and unscrew the pushrod from the clevis just enough to eliminate all the free play (meaning you can't pull the lever any farther away against the spring pressure). Now turn the locknut without turning the pushrod until there is a 0.1" (Girling) or 0.08" (Lockheed) gap between the nut & clevis. Next turn the pushrod back into the clevis, letting the locknut turn with the rod, until the nut just touches the clevis. Tighten the nut and you're done. This process is in the workshop manual, pages D4-D5.
PS, not mentioned, but perhaps significant, the slave piston should be pushed into the cylinder as far as it will go before checking the freeplay. Normally it would be there already from the action of the spring, but it can't hurt to push on the pushrod and see if it will move more.
Lukens
Lukens
Randall, I understand... best to check free play with the spring disconnected. And I don't know why I said .010? I usually just give it some play by feel, maybe 1/32 or more. I always check it frequently to confirm that it free.
I'm back in business now. The problem was that the slave seal was so too tight. The slave spring couldn't override the friction. The clutch fingers would push the TOB back to their limit but the slave spring couldn't push the piston back further. Then I'd shorten the rod to create freeplay and the same scenario would repeat. Each time I did this the piston would inch it's way out of the cylinder.
I can't figure why the seal was so tight. I replaced it less than 1000 miles ago. I'm using Castrol GTLMA synthetic. Anyway, I replaced the slave and everything is working as it should.
One other thing. I mounted the slave on the tranny side of the bellhousing. I had to cut 1/2" off of the slave push rod to get freeplay. Strange?
TR3driver
Do you mean the slave on the rear side of the bracket? That would do it. Bracket on the rear side of the flange would be normal, unless you have a later TR6 gearbox fitted (like mine).
It's confusing because the manual shows the earlier Lockheed slave, which mounted differently than the Girling slave. This is the correct setup for Girling
I also found that, when I shortened the pushrod, the spring became too weak to return reliably. I solved the problem by adding a little tab to the slave mount, to stretch the spring an extra 3/8" or (roughly the same amount I removed from the pushrod).
Lukens
Lukens
Of course... I've got mine back aswards.
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
R Clutch Hydraulics Spridgets 4
P TR6 Clutch hydraulics Triumph 6
TR3MT TR2/3/3A Clutch Hydraulics II Triumph 8
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
Lukens TR2/3/3A More questions concerning clutch hydraulics Triumph 9
JPSmit Trivia question - clutch hydraulics Spridgets 16
Kleykamp clutch hydraulics ??? Triumph 8
John_Mc Clutch hydraulics-to hone, or not to hone? Triumph 14
Nunyas T-Series Sloooooowwwww leak in Clutch hydraulics MG 38
SunbeamTom Clutch hydraulics rebuild Sunbeam (Rootes) 2
danielnorton After Marke slave cylinder for clutch hydraulics? Spridgets 20
Brosky Silicone vs Dot 4/5 in new CLUTCH hydraulics? Triumph 17
MGTF1250Dave TR2/3/3A TR3A Clutch Hydraulics Triumph 8
J TR4/4A TR4A clutch hydraulics Triumph 2
zimmy bleeding new clutch hydraulics Spridgets 19
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
