General Tech HS6 Carburetor Bushings
KVH
Has anyone used a small lathe to drill out old SU carb bushings and press in new ones? If so, how did you secure the carb body to the tail stock—so it was square and firm in place?
I used a drill press with a machine vice to hold the carb body.
If I were doing it in a lathe, I would first try to hold the carb body in a 4 jaw chuck, and use the drill/reamer on the tail stock chuck. You can use the chuck with a rod through the carb throttle bore to align the body on the 4-jaw.
It looks like they did it by hand...which will work fine if you have a steady hand and don't rush it.
In a lathe, I would mount the carb body to the spinning 4-jaw chuck. 2 opposing teeth on the machined carb inlet/outlets, and the other 2 teth as necessary on the rounded outside of the carb body. Use a drill type chuck in the tail stock, and use a rod in the chuck to help center the tail chuck to the throttle shaft bore. Then spin the carb and, using a drill in the tailstock, drill and final ream the carb bore. You will not need your carriage tool holder at all for this operation.
Does the drill bit accomplish the reaming, or is a reaming tool then needed as well. Also, do you know whether the new bushes, which I believe are 3/8 inch, will press cleanly into the carb sleeves, or is that where more reaming may be needed?
Normally, you would drill with a 23/64 drill, and follow with a 3/8" reamer. The 6 flute reamer is much more accurate than a 2 flute drill bit. If you have ever closely watched a 2 flute drill, it creates a hole with 3 wallows in the hole, by it's nature. The 6 flutes of a reamer remains centered for a near perfectly round hole. Of course, if you only have a 3/8" drill bit, you can get by with that.
You would probable need a straight flute reamer. Known as a chucking reamer. Unlike a hand reamer which is tapered over the first section the chucking reamer is parallel.
David
I saw one clever technique where the guy pulled a long reamer backwards through the body, using the shaft of the reamer for alignment. In that case, no need for even a drill press. Not every reamer can be used that way, though.
(Edit: I just noticed your link, above. That may be what I'm remembering.)
If I were doing this again, I'd blow for a good reamer that was long enough to go through both bushings simultaneously. Then I would make bushings with a slightly undersized ID, press them into the body, and finally ream them to the right ID.
My experience rebuilding 4 sets of HS6 carbs is that the butterfly shafts took the wear rather than the carb body. This is different from the H6 carbs due to a very different linkage setup. I would suggest that you fit a new set of shafts into the carb bodies and then determine if you need to ream and bush the bodies.
Charley
That’s what I plan to do, first check play with new shafts. From what I now see, the worn shafts appear to account for about 2/3rds of the play. I can see that the old bushes suffered some of the mutual wear. But maybe acceptable. Once the new shafts and butterflies are in I’ll sure be reluctant to rethink it all. So it’ll be a judgment call.
(See the price of that oversize reamer Moss offers? Sheesh. My goal wouldn’t be to oversize in any case)
But about reamers, why not order a 7 inch one with 1.75 spiral flute and work backward as the write-up shows? Seems right. The ones I found have a shaft just under 5/16 ID and that may work. Not sure why the Moss bushings weren’t used. He ordered his from MMC.
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
S HS6 Carburetor Austin Healey 16
G SU HS6 Carburetors Needle Jets Selection Austin Healey 3
F TR4/4A SU HS6 jet initial adjustment jet not flush with bridge Triumph 7
F TR4/4A Replacement air filter for SU HS6 Triumph 6
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
Y TR6 SU HS6 question Triumph 1
J TR6 Moss HS6 SU conversion kit question Triumph 4
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
D TR4/4A SU HS6 throttle spindle size Triumph 20
BLong63AH HS6 BJ7 Carb Insulators Austin Healey 5
T TR4/4A HS6 problem Triumph 6
KVH TR4/4A Wish I Could Give Up--My Carbs Still HS6 TR4A Triumph 27
TRMark TR4/4A Convert from H6 and log to HS6 and 4A intake Triumph 6
trotti Calling all SU experts - Volvo HS6 Carbs Austin Healey 11
gbtr6 TR6 SU HS6 carb needle questions Triumph 17
KVH General Tech HS6 SU Carbs Triumph 1
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
A BJ7 with HS6 SU Carbs - which needles Austin Healey 1
Simmo TR2/3/3A HS6 Carburettors Triumph 4
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
G TR4/4A tr4a hs6 carb Triumph 1
H TR4/4A 4A Throttle linkage for HS6 SU Triumph 2
Hap Waldrop SU H6 and HS6 carbs Triumph 9
B TR6 Hitachi HS6 HIF rebuild/TR6 Triumph 1
T SU HS6 tuning - lifting pin question Triumph 11
Lotuswins HS6's on a BJ8 motor Austin Healey 11
H TR6 TR6 HS6 Needle selection Triumph 0
TR4nut TR4/4A TR4A HS6 Factory writeup? Triumph 9
KVH HS6 SU Carbs Triumph 2
K H6 SU carb dome and HS6 carb dome? Triumph 9
T HS6 idle setting Triumph 3
R SU HS6 Carbs overflow leaking........... MG 20
T NLA SU HS6 part request Triumph 10
T Anyone have a spare HS6 pivot bolt Triumph 13
T One more SU HS6 question Triumph 25
T Float & needle adjustment on SU HS6 - slightly OT Triumph 20
KVH TR4/4A SU-HS6 Carb "Choke" Issue--My TR4A Triumph 8
T TR2/3/3A Will HS6 fit in TR3? Triumph 10
H HS6 Fixed needle centering tips Triumph 1
B Measurements of HS6 Carb MG 12
H TR6 TR6 HS6 Conversion Triumph 6
H HS6 JET identification Triumph 2
H TR6 Volvo HS6 Carbs on a TR6 Triumph 9
H TR6 HS6 RUNNING TOO RICH ON TR6 Triumph 11
H TR6 HS6 for Tr6 -Pics Needed Triumph 1
T TR6 HS6's on a TR6 Triumph 14
chicken is this the correct float for a HS6 carb on a BJ7 Austin Healey 4
