How to run a business - Peter at World Wide!
tdskip
Guys - some credit where due. I've used Peter for a BGT (since sold on) and the TR4. The TR6 I'm focused on now also needed new rear dampers, and based on the great experience I had previously I ordered a set of replacement dampers from him in <span style="font-weight: bold">July</span>.
I received the damper set about a week later and then they sat there until last Saturday when I finally got around to opening up the box and realized that they went a set of TR4 dampers.
Now - to be perfectly honest - it is entirely possible that I messed up and asked for the TR4 rather than TR6 dampers I needed. And in any case, it's been like 1/2 a year now since I ordered them. I packed them up, put a note in explaining what I needed, and shipped them back.
Fast forward to Thursday - Peter calls and is honestly concerned that this happen and sincerely apologizes for the goof (even though it well could have been my error) and prompts ships the correct ones out to me. He even asked why I waited to request the new ones until I returned the TR4 set. He would have shipped the new ones before receiving the old ones back (I wanted to get them back first before asking for the correct set to be sent - kind of seemed fair).
I'm a customer for life now - and while I was really happy with them before I'm just thrilled we have Peter and company as a resource.
If you have never worked with them before please keep them on speed dial if you ever need dampers. They are a super resource for us and deserve our support!
Moseso
I went there for a TR3 shock rebuild. Very accommodating and prompt. And the shocks work fine too... One more vote for Peter.
Heck... At the risk of becoming too "political," (and a bit over-the-top) Peter for President!
JPSmit Tonight's ice cream run Spotted 3
shadowfever Shake down run Spridgets 2
L MGB 1977 MGB will only run on full choke MG 53
S TR2/3/3A problems getting the engine to run correct Triumph 21
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
S TR6 Anti Run-On Valve question. Triumph 4
A MGB-GT Video- Three minute run through Smugglers Notch in Vermont. MG 4
A Spitfire Video- Three minute run through Smugglers Notch in Vermont. Triumph 4
D Spitfire 20-50 oil says run in car manuel Triumph 6
DrEntropy MGB Shakedown run MG 6
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
S My 68 sprite hit and run Spridgets 10
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
steveg Anti-run on solution Austin Healey 10
D Been waiting for a hot day run Austin Healey 4
B MGB New Dual SU's and Run-On MG 3
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
Marvin Gruber TR4/4A Almost a burnt run Triumph 12
PeterK Spitfire OK then but will it run Triumph 6
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
RickB MGB Taking a run north this weekend, Bellingham & Blaine MG 4
P TR6 Won't start after 10-mile run Triumph 21
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
1 TR6 Tr6 needs choke to run good Triumph 11
H Rad bulkhead plates production run? Austin Healey 8
M_Pied_Lourd TR4/4A TR4 fuel line run. Triumph 5
L BJ-8 Engine run-on Austin Healey 21
RichBall Parts Run Spridgets 3
John_Mc General TR The secret to a 12 Parsec Kessel Run Triumph 1
T TR2/3/3A Can I run engine in car with no transmission? Triumph 7
J Found an E Type in a Barn. Bought it. Let's Make it Run Jaguar 15
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
D LSR test run Racing 2
L What is the rustiest, most run down Healey you have ever seen? Austin Healey 56
KVH TR4/4A Pre Ignition Run On Triumph 2
bighealeysource TR6 TR6 will not start back up after being run for a while and engine warm Triumph 15
angelfj1 General TR last run with the lady Triumph 19
S TR2/3/3A Ignition Run-On Triumph 5
D TR6 Anti run-on valve Triumph 3
Gliderman8 TR6 Starter energizes when in RUN Position...... Triumph 17
Keith_M Breakfast run Austin Healey 3
R reason for it said 1500 has cooling [run to hot] problems? Spridgets 20
B Strombergs Run Rich Triumph 12
NutmegCT TR2/3/3A low idle after a fast run - TR3 Triumph 4
Tinkerman TR2/3/3A TR 3A engine run in specs. Triumph 4
Tinkerman TR2/3/3A 60 TR3A Will not run above idle speed, help! Triumph 11
J TR4/4A TR4 won't run correctly Triumph 13
G Run on DIeseling RESOLVED Triumph 7
M TR4/4A 67 TR4A hasn't run for 10 yrs+... suggestions? Triumph 11
