MGB How much Torque can a standard MGB gearbox handle?
al1978
I am supercharging my MBG and am wondering if my gearbox will be able to handle it. I will probably be getting about 180 horsepower max not sure on torque. what sort of power can these box's handle?
jlaird
Well guess they hold it for the racer guys except they seem to use a lot of rear axles.
Dave Russell
Yoda - R.I.P
Re: How much Torque can a standard MGB gearbox han
The "racer guys" usually don't use supercharging. The differences are illustrated as follows.
Going by these formulas,
HP = (Torque X RPM)/5252
and
Torque = (HP X 5252)/RPM
You can see that as rpm increases torque decreases for a given horsepower output.
Since street supercharging gives an engine considerably more torque at a lower rpm, & torque is the limiting factor on gear box strength, it's anybodys guess how well the gear box will hold up. Probably OK if you don't drive it at the max all of the time.
As an illustration, a stock engine that develops 90 HP at 5500 rpm would likely have a maximum torque of100 lb/ft at 4000 rpm.
Assume a conventional race engine that develops 180 HP at 6500 rpm & maximum torque of 140 lb/ft at 5500 rpm or 147 HP at 5500 rpm. Much of the horsepower gain comes from increasing the rpm at which maximum torque occurs.
If the supercharged engine develops 180 HP at 5500 rpm, & 160 hp at 4000 rpm, the torque would be 210 lb/ft at 4000. The supercharged engine would develop 50% more torque than the conventionally modified engine, & 210% more torque than the stock engine.
The above numbers are for illustration only. You can work out the numbers for your setup.
Edit:
Remember that more torque = more cylindr pressure = more stress on head gaskets = more stress on crankshafts = more stress on rods, pistons, & bearings. Not just the gear box,U joints & axles. Engine life will be shorter. Engines purpose built for supercharging have the strength of all these components increased.
jlaird
And that of course is why they use so many rear axles.
Deleted member 3577
4 speed boxes are pretty darn strong & I don't think you'll have any problems.
Don't know what kind of rubber you are planning on running or the type of clutch your going to be using.
(I'd use the heavy duty MGB pressure plate rather than a Tilton)
Keep an eye on your U joints.
So far as the rear end goes.....No problem there either.
(The MGB uses stronger axles than the Spridget)
Steve_S
Gearbox should be fine. If you have an overdrive fitted, you better be careful with it.
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
S BJ-8 SU Fuel Pump Clicks Much Faster Than Before Austin Healey 9
DrEntropy MGB Differential with too much lash MG 5
HealeyRick Why 100Ms Cost So Much Austin Healey 14
Rut How much does a 1275 weigh? Spridgets 8
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
Healey Nut sooooooooo , how much will it go for ?? Austin Healey 24
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
GTP1960 TR2/3/3A How much is to much fretting? Triumph 10
NutmegCT So many cars! So much has changed! Other Cars 10
D TR4/4A How much play acceptable for input shaft bushing? Triumph 2
HealeyRick How Much is that Healey in the Window? Austin Healey 7
TomMull Air Compressors, how much is too much? Restoration & Tools 7
glemon How much paint? Restoration & Tools 8
Trevor Jessie Waaaay too much body roll Spridgets 14
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
DornTRoriginal General Tech The Devil is in the Details! Am I asking too much? Triumph 21
Lukens TR2/3/3A How much travel at the clutch slave? Triumph 12
S How much grease for the drive [prop] shaft plunger Austin Healey 3
J How much movement in slave cylinder plunger . Austin Healey 2
T TR2/3/3A How much vibration in a Triumph 4 cylinder engine? Triumph 12
J Clutch fork free play on BJ8 How Much? Austin Healey 13
F Too much procrastination[maybe long winded] Austin Healey 9
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
richie TR4/4A How much oil is normal.. Triumph 6
drooartz How much fender beading for Bugeye? Spridgets 17
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
Jim_Gruber How much spare fabric in needed to cover panels / dash on a BE. Spridgets 10
J New engines burning oil, Too much fuel? Triumph 14
B How Much Pedal? Spridgets 2
J How much to buy an engine block and head? MG 3
johnrip how much gas for winter storage Triumph 17
V TR2/3/3A TR3A Brake Pedal - Too Much Travel Triumph 6
AN5Sprite T-Series Considering an MGTF, how much $$$ MG 20
nevets How much brake fluid to fill the system? Austin Healey 3
W 2012 Daytona 200 - missed it by that much British Motorbikes 6
rkep01 How much do you think this will sell for? Spridgets 33
F T-Series How much to pay? Photos of 1955 MG TF 1500 MG 17
F How much of a premium? BJ8 vs. BJ7? Austin Healey 16
CZ_Dave One is too much, a hundred isn't enough MG 4
R Getting Much Closer Triumph 73
Darrell_Walker Leaks, some fixed, some maybe not so much Triumph 7
F Am i Worrying to much??? Spridgets 9
V How much extra engine oil with oil cooler??? Spridgets 5
Got_All_4 TR2/3/3A TR3 leans too much to the right Triumph 10
