TR6 How does this steering lock come off
Got_All_4
Trying to free these up and doesn't look like there is a way to separate the two half's. No heads to grab onto and looks like it was mad that way. Please advise.
martx-5
Yeah, those are sheer bolts. Made to be tamper proof. It might be possible to walk the bolts out with a small chisel, or probably best to just drill the heads off of the screws. Center punch it, start with a small drill and go about a 1/4" deep and then go to larger sizes until the head falls off.
Tybalt
They used breakaway bolts to install the steering locks. See that "dimple" in the middle of the fastener in pictures one and three, that's what's left of the "breakaway bolt head." You will have to drill out whats left of the "head" of the bolt to remove them. When you get the head to separate from the threaded portion on both bolts, you will be able to remove one of the bracket halves and get the rest of the bolts out of the other half. Then when you reinstall, use socket head screws to make it easier for the next guy to remove the steering lock.
bobhustead
When I was a BMC line mech, we had a recall of MGB ignition locks attached with the same bolts. I removed dozens using the corner of a small sharp chisel to rotate them out. A drill sounds good, but we couldnt get them in position on the Bs
dklawson
While you can drill, chisel and punch the "head" of the shear bolts out, I use a different method.
Take a die grinder with a 1/16" thick cut-off wheel and slice into the diecasting and the heads of the bolts. This makes a screwdriver slot. You might find a screwdriver can then be used to remove the bolts. More likely, you'll need an impact driver to back them out. Regardless, cutting and using the slot is fast and easy compared to other methods.
When you put the lock back on, don't buy new shear bolts (unless you really think a thief is going to look to see what fasteners are there). Instead, visit the hardware store and buy regular socket head cap screws. Check to confirm this... but I believe the locks use common 5/16-18 (coarse) threaded bolts.
Got_All_4
Got_All_4
That's what I was afraid of. I like Dougs screwdriver slot method. While I was reading the replies I'm thinking of getting out my left hand drill bits. Bob I'm sure back in the day a chisel would have worked fine but I'm thinking that over the decades there got to be a lot of corrosion from the 2 dissimilar metals and I'm thinking of adding some heat to the aluminium because it will expand faster the the bolts. Although this is a parts car and what I'm using from the car is going into a 69 which doesn't have the steering lock. I would eliminate it if it was going back into a 70.
With Doug, cut a screwdriver slot using die grinder or dremel tool. Have done it several times with the lock still in the car. The sheer heads break off with little pressure so they don't need much to be backed out. Put back with regular bolts.
Marv
Got_All_4
Got_All_4
Cutting that screwdriver slot worked great. One side came right out and the other a little heat did the trick. Thanks!
dklawson
Great! As I mentioned earlier, for re-assembly regular socket head screws will work fine in place of the shear-head bolts. Once you install regular screws you won't have to go through this again!
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
Lbp TR2/3/3A Looking for info on adjustable steering wheel - Does a Healy wheel fit? Triumph 9
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
AUSMHLY Does your steering wheel touch your legs? Austin Healey 7
C How does one clean a BE steering wheel? Spridgets 4
X What car does this steering wheel belongs to? MG 12
L What does this column switch do? Spridgets 4
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
J MGB HELP, my horn does not work! MG 8
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
S TR2/3/3A overdrive does not function Triumph 45
Bayless How does '67 Sprite top attach to body? Spridgets 3
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
B General MG Does odometer record when flat towing. MG 5
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
TomMull TR2/3/3A rear mount does not line up Triumph 10
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
JPSmit Fuel tank sender - how does it work? Spridgets 4
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
S TR2/3/3A What does a condenser do? Triumph 21
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
D Does this count as British car? Spotted 18
BN6_2197 How does the flasher unit work Austin Healey 4
J TR6 Does this sound ok to you? Triumph 5
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
B Does anyone still make or sell a quality condenser? Austin Healey 14
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
F How does overdrive Annulus effect speedometer Austin Healey 10
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
B MGA What does this founder mark mean? MG 4
D TR2/3/3A Gas tank does not fit! Triumph 4
Gerry M TR6 Overdrive does not engage Triumph 13
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
C TR6 ZS 175 What does this screw do? Triumph 2
HealeyRick Who Knew Martin Jansen Does Bikes? Austin Healey 0
Rut How much does a 1275 weigh? Spridgets 8
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
D TR4/4A how hot does the timimg chain cover get? Triumph 15
D TR4/4A Does a bolt legend exist? Triumph 3
