Does your steering wheel touch your legs?
AUSMHLY
Hi Guys,
I just installed the factory 16 1/2" banjo steering wheel.
Those who have one, how much space is between the bottom of the wheel and your seat top?
I'm thinking the distance may be relative to the padding in the seat, and what's under the seat rail. Like the wood and metal strips.
I've heard that with some people, the wheel touches their leg.
I just switched out my 15" Mota-Lita to the 16 1/2" banjo.
Quite a difference in feel.
1. The 16 1/2" diameter makes steering easier.
2. It has more flex, as I'm guessing that is the reason behind using the wire spokes. (It absorbs some of the car vibration.) (You don't feel as much of the road, which some may want.)
3. The rim is thinner too.
I've heard some people switch to a smaller steering wheel because of items 2 and 3, and also because the wheel may touch their legs.
I'm happy to say, I love the feel of the Healey steering wheel. For me it's about getting as close as possible to the feel of what was, when my Father drove his 64 BJ8. My beloved Father and I were the same size.
Cheers,
Roger
nevets
Like you, I prefer the look/feel of the stock banjo style steering wheel. My wheel doesn't touch my legs but I don't have thunder thighs. Santa might have a problem though. I suppose a smaller wheel would make getting in/out of the car a little easier.
Randy Harris
I can barely squeeze by the wheel with my aftermarket Moto-Lita wheel. My original wheel which is hanging in the garage (in pathetic condition I might add), would be a deal breaker.
Randy
dougie
I have a Moto-Lita wood/aluminum wheel on both by street and race car. For me, the original banjo wheel is just to weak and fragile looking. As I recall DMH said they were designed to be replaced so very little time and money was put in them. Today we call this "value engineering", he want to use a wood/aluminum style like the Aston Martin but the production costs were too high for the Healey price point.
Like like Donald's original plan:
Editor_Reid
Platinum
A lot depends on the seat bottom. On my 100M - seldom driven and seats "as new" or better - there is a definite clearance issue. On my 100 Le Mans - often driven, and seats "broken in" - there is no issue.
It's also interesting to look at period photos of early Healey seats and note that the seat bottoms did not have a lot of "fluff" or bulge - they often looked broken in/down right from new. It must have helped avoid leg-steering wheel clearance issues, even if only unintentionally.
editor reid, any info on how tall/short donald healey was?, at 5'6 and 1/2" i find the healey very comfy all around, from pictures ive seen of him he doesnt look very tall.
GregW
Platinum
Not wanting to go to the hassle of re-doing the foam, I used a chain saw to notch my thighs.
Cottontop
When I switched to a 69 Opel GT instrument panel, I had to lower the steering column almost 1 1/2".
Then I switched to MGB seats which raised the seat height an inch or so.
The answer was to reduce the steering wheel diameter from the stock 17" down to 13". That was the easy part.
The wheel doesn't touch my thighs, but losing the 40 pounds so that it doesn't rub my belt buckle has been much harder.
Tim
Lbp TR2/3/3A Looking for info on adjustable steering wheel - Does a Healy wheel fit? Triumph 9
C How does one clean a BE steering wheel? Spridgets 4
X What car does this steering wheel belongs to? MG 12
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
Got_All_4 TR6 How does this steering lock come off Triumph 9
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
L What does this column switch do? Spridgets 4
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
J MGB HELP, my horn does not work! MG 8
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
S TR2/3/3A overdrive does not function Triumph 45
Bayless How does '67 Sprite top attach to body? Spridgets 3
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
B General MG Does odometer record when flat towing. MG 5
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
TomMull TR2/3/3A rear mount does not line up Triumph 10
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
JPSmit Fuel tank sender - how does it work? Spridgets 4
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
S TR2/3/3A What does a condenser do? Triumph 21
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
D Does this count as British car? Spotted 18
BN6_2197 How does the flasher unit work Austin Healey 4
J TR6 Does this sound ok to you? Triumph 5
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
B Does anyone still make or sell a quality condenser? Austin Healey 14
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
F How does overdrive Annulus effect speedometer Austin Healey 10
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
B MGA What does this founder mark mean? MG 4
D TR2/3/3A Gas tank does not fit! Triumph 4
Gerry M TR6 Overdrive does not engage Triumph 13
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
C TR6 ZS 175 What does this screw do? Triumph 2
HealeyRick Who Knew Martin Jansen Does Bikes? Austin Healey 0
Rut How much does a 1275 weigh? Spridgets 8
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
D TR4/4A how hot does the timimg chain cover get? Triumph 15
D TR4/4A Does a bolt legend exist? Triumph 3
