Heater/Heater Core..........Durrrr!
AngliaGT
I decided to take off the heater hoses,to replace them,
& broke the metal piece that the hose goes over,on the heater core.
What's the best/easiest way to pull the heater box?
- Doug
Pop the clip's off the box and the core comes right out.....least that's the way it is on the early cars. I imagine its just as easy.
Kurt.
WRONG!!! - I removed the screws from the front of the heater box,pulled ALL of the clips on the heater box,and .......... NOTHING. I even removed the battery.I still have to find a way to remove therusty/battery stained (2) screws that hold the rear heater base in place. - Doug
What year are you disassembling?? BE through the 60's at least required removing the clip's and the core came out the front of the box.
Kurt.
They changed to the one piece box in late '71 ... I think.
It's an early (11/73) '74 - 1275. Looks like I'll need to pull the hood off,to get the screws out without messing them up. - Doug
Ithink the original screws may have a posi drive head. If so, using the right tool greatly increases your odds of success.
Had our Granddaughter hold the hood up,to remove the battery.Got the battery out,but had to remove the hood to figure out how to removethe screws from the base of the heater box. John,a Master Mechanic,came over,& helped me figure out how to remove the screws,without resorting to destroying them. Pulled the heater box out (By the way,only the back part comes offeasily - 2/3rd - 1third).Now I need to paint/re-install. "Reassembling is the reverse of disassembly"........... - Doug
Wow, yes, Trevor! So many folk's are unaware of the need for pozi-drive screw drivers. Impact driver can come in mighty handy too on occasion.
Kurt.
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
C Testing heater core Austin Healey 9
HighAltitudeTR3 Wanted Heater Core, Capping Trim, OD switch 1959 TR3 Triumph Classifieds 3
R TR2/3/3A Heater Core Triumph 2
R Radiator Heater Core Austin Healey 12
S TR2/3/3A heater core Triumph 4
Jake Healey 100 heater core size? Austin Healey 1
AngliaGT 11/73 Midget MKIII - Heater Core Foam Thickness? Spridgets 10
Got_All_4 Wedge Heater core leak. What am i in for? Triumph 3
B TR6 TR6 Heater core plugged? Triumph 9
Pythias Heater Core Replacement Spridgets 7
D 85 XJ6 Heater Core Replacement Advice Wanted Jaguar 19
George Zeck Heater Core & Battery ...... Spridgets 5
Luke_Healey Cheap options for a heater core? Spridgets 11
mgbmedic Wedge 1980 TR7 Heater Core Triumph 2
N MGB What came out as I pulled the heater core for MGB MG 7
L Heater Core Testing Spridgets 4
OregonTR4A TR4/4A Help with Heater core in a TR4A Triumph 3
rlandrum Heater Core Motor Triumph 10
N Heater core Question Triumph 10
B Midget 1500 Heater core flow Spridgets 3
M TR2/3/3A TR3 Heater Core PSI Triumph 3
Brosky TR6 TR6 Heater Case/Core/Motor Repair 101 Triumph 4
O TR6 Pressure testing a TR6 Heater core Triumph 16
msoylemez heater core to valve on block not aligned Spridgets 12
AUSMHLY Water Leaking - Heater core and core plug Austin Healey 7
S Wedge TR7 Heater Core Triumph 1
bmurphy7369 Audi 100... Heater Core Monstrosity! Other Cars 5
EMGEBE Heater Core MG 26
BierRunner TR6 Heater Valve Triumph 18
E Heater install Spridgets 2
R TR6 Heater control bezels TR6 Triumph 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
R TR6 Heater box Triumph 6
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
D Heater knob removal Spridgets 6
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye heater cable Spridgets 12
E austin van heater removal Other British Cars 0
Lin Heater water valve question Spridgets 2
T Bug Eye Heater Switch Help Spridgets 2
T Heater Door Spring Austin Healey 1
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
H BJ8 Heater Valve/Control Tap Austin Healey 3
jlaird MGB Heater MG 5
