TR4/4A Headlight switch wiring. Please help
shoopal
65 TR4A. Light switch on stalk. 5 wires coming out of the switch harness. There are 3 heavier gauge wires , A Blue (U) a Red with a green stripe (RG) and a Brown with a green stripe (NG).
When in off position no wires connect. When in middle position NG and RG connect. In the top position NG connects to both U and RG. There are also two other wires of a smaller guage, a brown and a blue/white stripe which don't seem to be connected to anything in any position whatever.
I assume that NG goes to the fuse box feeding from the Ignition switch. RG feeds the other fuse which goes to the marker lights and instrument gauges lamp rheostat. The U goes to the dimmer switch which feeds the headlights.
The question is where do the smaller wires go? They don't seem to have any purpose.
Help please
Al Shoop
Andrew Mace
Offhand, no guess on the smaller brown wire, but it must provide power for something? The blue w/white stripe wire could go to the other such wires on the high beam circuit; it is for the "flash-to-pass" function, something often NOT connected originally on US-spec. cars depending on local laws.
S
shoopal
You are probably right. On close inspection, I see that the smaller wires go to contacts inside the switch which have no mates. Looks like it was set up for something to happen if one pulled the stalk. Maybe like a high beam flasher or somesuch. The spring would indicate that the plastic base would be moveable but it is not.
Update. I have two switches. One from a 65 and one from a 67. The pictured switch is the spare that I was playing with. Not sure which one it is but I think it is the 65. The installed switch stalk will pull and connects the two small wires.
The wiring diagram in the manual shows the 3 wired setup, the Dan Masters diagram (attached) is a bit confusing but does show the 5 wire setup. It's getting more clear how to wire this up. My only question is why did they use a smaller wire for the headlight flash (short term pulses?) vs the larger wires from the dimmer switch (on for long duration?)
Well, onward.
By the way, if anyone wants the pictured switch, free plus shipping costs (good condition except the stalk chrome is pitted up)
R T-Series Wiring harness - headlight switch MG 3
B Headlight Dip Switch Austin Healey 4
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
Upland 3 position headlight switch is now 2 Spridgets 1
S Replacement Headlight Switch Spridgets 4
Z TR6 74 TR6 - Changing headlight beam switch issue Triumph 0
T TR2/3/3A Is there a way to take apart and clean/repair TR3A headlight dimmer switch? Triumph 8
R Headlight switch replacement on BN7 or BJ7 cars Austin Healey 3
britndablood WTB original Pull Headlight Switch and Choke cable Austin Healey 5
R TR4/4A headlight switch TR4a Triumph 34
Newkie T-Series Turn signal headlight dimmer switch question? MG 2
HAN8L1965 Headlight Dash Switch mkIII Spridgets 4
AUSMHLY Headlight switch - fried Austin Healey 23
wkilleffer T-Series Problem with the headlight dip switch MG 1
Newkie T-Series Headlight Dimmer Switch help MG 0
A T-Series MG Headlight switch MG 6
Bob McElwee Dash Park/Headlight Switch Austin Healey 6
J T-Series Electrical Problem: headlight switch turns starter MG 28
S New Headlight Switch but no Lights Triumph 21
2wrench TR6 What holds this TR6 headlight switch in place? Triumph 12
MGTF1250Dave T-Series MGB Headlight Switch Gets Very Hot MG 15
wkilleffer T-Series Rant about turn signal and headlight switch MG 37
D Headlight Switch Spridgets 9
J hot headlight switch! Triumph 6
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
F TR2/3/3A Headlight bucket color Triumph 22
F TR2/3/3A Headlight bucket clip Triumph 2
Healey Nut Headlight buckets Jaguar 3
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow For Sale Used headlight rims for sale Austin Healey Classifieds 1
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
Guido36 LED Headlight Upgrade Austin Healey 1
Healey Nut TR6 Headlight size Triumph 58
D BJ8 Headlight Rims Austin Healey 0
D TR2/3/3A snap on headlight rims restore Triumph 10
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
Spock TR6 '72 Headlight Relays Triumph 4
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
D TR2/3/3A Headlight Trim Triumph 17
P TR6 ^%$#headlight rim Triumph 4
KVH General TR Headlight going out Triumph 9
Rob Glasgow Weird Lucas Headlight Austin Healey 7
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
P TR6 Headlight problem Triumph 3
