I just installed TRF seals with no problem. Someone in this forum suggested that you install the hub without the seal, adjust for proper bearing adjustment, then mark the nut and hub with a sharpie, note number of threads. Remove hub, install pre worked in grease seal. Tighten till it aligns with sharpie mark and thread count. Also, make sure you have the felt pointed in towards center of the car
