Finding an accurate tyre pressure gauge?
twas_brillig
Jeff was over with his Snap-on analogue tyre gauge (it read 28 psi on our test tyre), and we compared that two of the traditional metal gauges with the (plastic) rod sliding out; one digital gauge, and a bicycle tyre pump with an integrated analogue gauge. Our five gauges gave us readings falling between 24 and 28 psi. Does anyone have suggestions as to a source for an accurate gauge, and how to test tyre gauges for accuracy? Thanks, Doug
JPSmit
no idea, but, surely 4 lbs difference - for tires (when you aren't racing) is close enough?
It is not only a matter of accuracy, but also precision (or repeatability).
nomad
Look for a good ol fashioned Milton.....still available I believe. Indestructible.
Kurt
1974MGMidget
Check out summitracing.com. They have pages and pages of gauges, all types, pressure ranges, and prices, including a Milton pencil gauge for $5.97! I have the JOES Racing gauge, and it seems to work fine. No idea how you would check for accuracy - you pays your money and you takes your chances!
D Finding a Posting FORUM Navigation Questions 4
G TR2/3/3A Finding a long lost TR3 Triumph 4
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
B TR4/4A Finding compression stroke Triumph 7
O Finding Gerard Spridgets 9
A TR2/3/3A Need Helping finding windshield bracket! Triumph 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
B TR4/4A Need Help Finding Triumph 3
T Finding help to actuallyl get projects completed Spridgets 4
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
M TR2/3/3A Finding top dead center Triumph 6
E Need help finding the builder to my 65 Spridgets 18
C Need Help Finding Torque Specs for Engine Austin Healey 1
S TR6 Finding a 69 tr6 Triumph 2
jhorton3 Finding Midgie A New Home Spridgets 0
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
justin_mercier Post-War Other Need help finding a triumph 2000/2500/2.5pi autobox transmission Triumph 10
R Finding old posts Austin Healey 5
S I need help finding a correct bolt. Austin Healey 8
A Finding the fun stuff! Triumph 4
7 finding a coolant leak Other Cars 8
F Need help finding a part- door window track piece Austin Healey 5
richberman Help in finding part: Longbridge hot air outlet Austin Healey 3
T finding a coolant leak Austin Healey 3
J Finding a correct 1964 BJ8 steering wheel Austin Healey 1
T Finding engine ID Austin Healey 7
N Help finding a part Triumph 7
T help finding stromberg parts Triumph 5
T longer wheel studs need help finding Triumph 11
A TR6 Finding TR6 Project? Triumph 22
R Help finding part Jaguar 3
M Finding Tires for Midget??! Spridgets 8
Basil Help finding part Jaguar 11
wkilleffer MGB Finding 74 MGB starter stuff near Chattanooga, TN MG 4
M finding vendor Spridgets 1
M finding vendor Austin Healey 3
Cyberpyr8 Need help finding a solution Triumph 23
T Brainstorm me a disagnostic finding Triumph 14
GeeBee1 TR6 Finding a late model TR6 Triumph 9
T Help finding grounding clips Triumph 6
G Finding TDC or Waiting For Godot Triumph 17
S Need Help Finding a Part Austin Healey 1
B Finding 50A Fuse for Horn Locally? Austin Healey 15
G Try finding THIS short..... Triumph 9
Bayless Finding TDC on a flathead motor Other British Cars 16
M Finding an old healey Austin Healey 5
bash Electrical fault finding Triumph 8
J Finding Exhaust Leak MG 4
floyd TR6 finding a tr6 repair manual Triumph 14
