Bill, it looks like the terminal came loose in the connector and melted the plastic(from what my ancient orbs can detect) and the wire crimp coming loose, wire insulation burning. Is this the case?
I would like to input a bit, in an attempt to correct some of the terminology. As proper labels, make it a lot easier to identify, describe, isolate, trace, diagnose and correct electrical problems.
You call yours a short. A short is when the voltage goes to ground and the circuit is broken by excess voltage draw(amperage, actually) popping the fuse, circuit breaker, or whatever is installed to protect the circuit. An open is when the terminals separate and electrical flow is interrupted. Usually caused by loose wire, terminal, heat and corrosion. In your case it looks more like an open circuit, the terminals weren't tight, and the continuous overheating of the circuit caused the insulation to melt.
