Anyone Try this Camera?
blkcorvair
https://www.goprocamera.com/
My Hard Drive SONY camera is not working for racing. I turned off the sleep mode and I turned off the drop protection but it still shuts itself off everytime I try to use it for racing. So I shall retire it to family video only and search for something else. This looked cool.
$200 for wide video and loaded on SD Cards? Looks like a win win? Anyone used it before?
aeronca65t
Yes.
I have one. I bought it to replace my JVC mini-DV camera (which the Sprite rattled to death after about a year).
I would not recommend the GoPro.
Attachment stuff (suctions cups, etc) is good and camera is waterproof, but the actual camera is poor. *Very* clumsy multi-function buttons to control it. I see other guys struggle with the controls too, just at the begginning of a race (just when you don't want any drama).
But the main thing is battery life. It's terrible. Even with super-dooper batteries (2 AAAs), it'll hardly last 45 minutes and more often, only 20 minutes or so. They sort of say that you need real good batteries in their info, but I don't think any battery can last in this thing. Plus there is no review monitor.
I have just built an external battery pack (2 C cells) for the GoPro to see if that helps, but I have not used it. I'll keep the GoPro as a backup.
Buy a ~FLIP~ camera. Also solid state. Much, much better. Better video and equal sound. Batteries (2 AAs) last much longer even though it has a built in monitor that allows playback. I can't figure out why the primitive GoPro is so hard on batteries compared to the Flip, but it is.
The Flip does not have a removeable memory card. It'll store one hour of video. I always bring my laptop so that's no big deal to me. Unloading video is simple.
The on/off/record buttons on the Flip work *much* better than the GoPro.
With the Flip, you'll need to build a mount, but considering all the fabrication work you're already doing, that'll be easy (I built one out of a plastic ketsup bottle.....I'll make something better for '09 :laugh: )
ThinkRacing
Member
I bought a Go Pro too and had similar issues. I thought the video was fantastic, but compared to my previous video capabilities, I am easy to please.
My brother-in-law accidentally deleted my first session, but I did get the second session. So, I thought. It quit recording after 1 minute and did not get any sound.
The flip sounds like a decent solution that I might have to try. Maybe I can recoup some cash from ebay with the Go Pro.
B
blkcorvair
I have a $120 rebate at staples. My wifes headed there now to get the flip for $129. 60 minutes of video will just have to do. Its a shame they dont take SD cards like the go pro
VelodromeRacer
I had run a Sony DV...but didn't like the idea that 1 rock to it and I lose the whole thing...I bought a Race Optics Dvr setup. I remotlr installed the DVR and then have a lipstick camera mounted to the rollbar...great setup as the thing has 1 switch that I velcro to the driveshaft tunnel. I throw when on the grid at the 3 finger mark...it is more expensive but it records on a 4 gig sd card and the batterys last me a day of track time and recharge in my tow car.
I have posted about 10 different videos on youtube under VELODROMERACER.
Eric
I have one and have been fairly happy with it. Yes, the controls are minimal, but you can set it up ready to go, and just push one last button when it's "time to go". The video quality isn't stunning, but it's far better than YouTube quality. I haven't had the battery issues described - I can get nearly an hour of video on a set of batteries. Make sure you're using NiMH batteries (I've got an Energizer charger and 2 sets of batteries), as regular alkaline cells won't cut it in any kind of digital imaging device.
A 2GB memory chip works fine - just have a few spares.
The thing I really like about it is the weatherproof (and rock-proof) housing that comes with it. The mounting pads work extremely well, and you can mount the camera nearly anywhere. I you mount if upside down, you can electronically invert the image with a single command.
I was disappointed with the sound quality however. I got a significant amount of what sounds like ignition noise on it, and this is on a street car with suppressed ignition.
JerryB
The narrower view (original) Go Pro works fine and is cheaper. Some sellers include a battery pack and extras in lieu of a discount below the MSRP. This saves you a 20 that you will spend for Batt and charger.
batteries MUST be 900ma NiMH or better. Charge after every session. See above post. I use 1000ma Duracell and the 4 battery Energizer charger.
You have to either turn the camera on before you get belted in or have someone push the run button. This wastes camera time on the grid but you can edit it out.
If you make a mount for it (like on a round tube) make sure its cushioned so not to get a wavy image.
Use low volume. You will get ignition interference (noise) if the cam is close to the battery or any cabling.
The suction cup mount is really gorpy. Make up a dedicated mount and use a lanyard under the case clasp.
Michael Oritt
I use a ChaseCam bullet cam and PDR100 recorder. The thumb-sized cam comes with its own mount that clamps easily to the roll cage. A 12 gig card will hold about two hours worth of racing. Video and audio quality are excellent though I do get some rear-end whine that transmits through the rollbar. I recently added a dash-mounted LAN switch with a red/green LED to remotely turn the unit off and on.
B
blkcorvair
Now Im jelous. My sister came over with her SD camera. Panasonic records onto SD cards. Very compact. About half the size of my SONY. Pais $200. May be putting that on my BDay list and offing the Flip to my Wife's editions of Baby cams.
MadMarx
T Victoria British seat recover kits- anyone try them? Restoration & Tools 3
Brosky Anyone ever try the "Synchrometer"? Triumph 33
G Anyone try this? Restoration & Tools 4
Basil Anyone remember Dave Russell? Austin Healey 10
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 35
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
Basil SS100 anyone? Jaguar 5
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
R General TR Anyone going to TRA in North Georgia? Triumph 0
R Wanted Anyone have one of these? Triumph Classifieds 6
mt10flyer TR2/3/3A Anyone race prepped a TR3? Triumph 3
Rut TR4/4A Sorry Top anyone? Triumph 0
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
