Need Help Finding Torque Specs for Engine
John Turney
From the Moss catalog:
- Cylinder head studs: 33 ft-lb
- Cylinder head nuts: 75 ft-lbs
- Rocker shaft bracket nuts: 25 ft-lbs
B TR4/4A Need Help Finding Triumph 3
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
E Need help finding the builder to my 65 Spridgets 18
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
justin_mercier Post-War Other Need help finding a triumph 2000/2500/2.5pi autobox transmission Triumph 10
S I need help finding a correct bolt. Austin Healey 8
F Need help finding a part- door window track piece Austin Healey 5
T longer wheel studs need help finding Triumph 11
Cyberpyr8 Need help finding a solution Triumph 23
S Need Help Finding a Part Austin Healey 1
KLUTZ MGB-GT Need help finding Previous, Previous owner 74.5 GT MG 6
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
