Doesn't smell like gasoline - just a horrible exhaust type of smell. Not all the time but when it is there it is BAD. Reminds me of when I used the Corolla liftback to haul stuff with the hatch open. I couldn't open the windows funnily enough because the exhaust fumes got sucked in.
I've had this car for over 10 years and it has just appeared.
Things I've done recently:
Replaced ZS with HS4.
Removed (non-functional) EGR valve - tightly plugged hole with nut.
Plugged hole in intake manifold with nut.
Installed bigger heat shield.
Could the stench be caused by an incorrect fuel/ mixture ie running too rich?
This is very strange - the ZS (22mpg) was running slightly rich but there was never this smell before.
Can't smell much under the hood with the engine running
