Exhaust flange
Baz
Every two weeks or so, I have to replace the nuts on the 3 studs that keep the flange snug.
I've tried shakeproof washers, double nuts and 50lbs of torque. Gravity has a way of making these nuts disappear.
Anyway, this flange was the culprit for my engine bay ghost heat (and why I felt sleepy and happy after about 1 hours drive) because it leaked enough with one missing, but not enough for it to sound course, as it does when two drop off.
Just wandered if there is a trick I can play without welding to keep these on?
Jim_Gruber
Got the support bracket that bolts to the tranny under there. I need to tighten up every once in a while all caused by bracket that I don't have. I've even had that loosen up the intake manifold once. Car would not idle below 3,000 rpm all of a sudden due to an air leak. I'd also speculate about worn threads on the bolts on the exhaust manifold.
Baz
Baz
There I was thinking about furnace putty.
Threadlock and Safety wire are things I'm not familiar with, if you think it'll do some good, I'm all ears.
Speedy_Pete
I'd get some lock washers. Before you do that though, are the bolts old ones? The bolts threads may be worn.
John Loftus
Good suggestion on the all metal self-locking nuts.
I've seen them called Aerotite or Philidas. British Tools and Fasteners carries them. Maybe even Moss since they were originally used on our cars in high heat areas.
Cheers,
John
Whitephrog
Speaking of British Tools, have anyone been able to access their website lately?
Bugeye58
Barry, for a 5/16-24 nut, the part number would be MS21042-5. MS21042 is the style of the nut,(see the Aircraft Spruce link I posted), and -5 is the size in sixteenths of an inch.
Jeff
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
Bob_Spidell Exhaust Flange Gaskets Austin Healey 8
newmexTR3 TR2/3/3A TR3A Exhaust flange gasket tips Triumph 8
RickB Exhaust flange blew out again this morning MG 33
RickB Exhaust flange blowout on way home from work MG 6
eschneider Help! Stainless exhaust flange needed Restoration & Tools 1
A Exhaust Flange Spridgets 3
guzzul Spitfire Help! Spitfire 1500 exhaust flange studs broken. Triumph 16
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 7
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A Exhaust Systems Triumph 10
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
