Cross Reference Source
Herald63nut
I am restoring a 63 Herald and understand that a number of parts used on it may also been used on early Spitfires and perhaps even TR3s and 4s. If so, is there a parts cross reference source available? Thanks.
TR3driver
Great Pumpkin - R.I.P
Don't have one handy to check, but I believe there is an "Also used on models" column in the numerical index of the factory Spare Parts Catalogue.
You can accomplish somewhat the same thing by looking the Stanpart number (from the SPC or Canley Classics, etc.) up on TRF's website. If it's the same as one of the models TRF covers, they'll have it listed.
Very few parts in common with the TR3/4, but more overlap with Spitfires I believe.
Andrew Mace
Lots of mechanical overlap with early Spitfires, and a fair amount of hydraulic and electric overlap as well. Someday, if I ever get a good OCR scanner, a bunch of time and initiative, I hope to put together some cross-references. But Randall's right: all the Standard-Triumph SPC's of that era had those "Also used on models" indices, and they're very handy, at least for Stanpart numbers.
IF I ever got REALLY ambitious, I'd further cross-reference to Lucas and Girling numbers....
Meanwhile, feel free to PM me, ask me through the Forum here, or send me an e-mail, and I'll help you c-r anything you want.
TR3driver
Herald63nut said:
TRF website?
Just go to https://secure.zeni.net/trf/ and enter the Stanpart number in the box on the left. If you get a match, there should be a code in the 'Description' box that gives a list of applicable vehicles. Eg, "S13" implies the part fits at least some Spitfire Mk 1, 2 & 3.
G TR2/3/3A Cross reference for hardware Triumph 8
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
H gear reduction starter cross reference Austin Healey 12
aeronca65t Spark Plug Cross Reference Restoration & Tools 3
PAUL161 Spark Plug Cross Reference. Restoration & Tools 1
T Helpful cross reference site for parts Triumph 6
T TR4/4A Fram or other spin-on cross reference for TR4a Triumph 7
roscoe Filter cross reference Austin Healey 3
A Headlight Cross Reference Spridgets 3
Y Cross Reference on Brakes for Europa Lotus 2
bmurphy7369 XJ6 S2 vs. XKE S3 Mirror Cross-Reference? Jaguar 5
S MGB Transmission cross member re-install MG 14
Healey Nut Cross Rod Correct Length Austin Healey 14
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
S TR2/3/3A Clutch cross shaft bushings? Triumph 5
F TR2/3/3A Throttle linkage cross rod Triumph 4
G 100/6 Radiator cross member Austin Healey 6
R Wanted WTB Spitfire race/auto cross car Triumph Classifieds 1
J TR6 TR6 Cross Tube Differences? Triumph 6
J front cross member height from bottom to floor on BJ8 Austin Healey 5
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
S Difficulty removing end rods and cross rods Austin Healey 11
S TR2/3/3A cross tube back on Triumph 3
J E Brake cross rods Other British Cars 6
PatGalvin TR2/3/3A Engine Cross Tube Challenges Triumph 6
RJS TR4/4A Clutch Slave mount into cross shaft Triumph 3
oxford steering cross rod Austin Healey 13
stuntflyr Solo cross country Healey frame transport. Austin Healey 17
Boggsy64 MGB Front Cross member pads MG 4
G 100-S in 1000 K cross country race Austin Healey 6
C 1500 gt pre cross flow Other British Cars 4
andrea Austin Healey 100/6 cross flow heater pipeclips Austin Healey 3
M TR4/4A TR4A muffler hanger to cross member attachment Triumph 13
C Ford 1500 Kent Pre-Cross Flow Mystery Lotus 20
bighealeysource Question on toe in and cross rod assembly Austin Healey 4
F Bias ply tires [cross ply tyres]- more for less? Austin Healey 36
J TR6 TR-6 Clutch Fork Cross-Bolting ? Triumph 2
G Auto cross tire pressure Spridgets 7
T MGB MGB cross country trip - NY Times MG 0
K TR2/3/3A TR3 Boot: The criss cross support bracket Triumph 2
Got_All_4 Auto cross videos from TRF Summer Party 2010 Triumph 0
T TR4/4A TR4/A cross-tube question Triumph 9
Nigel_Johnsfolly LBC Cross-Country Rally Other British Cars 2
Nigel_Johnsfolly LBC Cross-Country Rally Spridgets 0
I Bugeye spares supplies for a cross country trip? Spridgets 13
mjobrien Top cross section at the front header / bow Austin Healey 0
Lynn Kirkpatrick MGB-GT MGB-GT Tranny Cross Member MG 5
M Wire wheels- cross fitting Spridgets 12
hondo402000 TR6 TR6 Clutch cross shaft Triumph 9
