TR2/3/3A Clutch cross shaft bushings?
Snowkilts
I'm doing the clutch and replacing the cross shaft bushings, amongst other things. I notice that the old one on the right side has a cutout while the left does not. I'm assuming this is to get some lube to the non-existent locating bolt, but it also has the effect of letting some grease come out of the locating bolt hole, which lets me know that grease is getting in when I'm greasing.
Since I am what would probably be considered an "enthusiastic" greaser, this is a good thing. On the inside of the bellhousing there was a lot of grease on the left side (without the cutout in the bushing) but hardly any on the right. I'm thinking of drilling a hole in both new bushings so that I always get a positive indication that grease is getting in but no accumulation inside where it doesn't belong.
What do you guys think?
sp53
Sure why not; you should be able to see in the bell housing with a mirror and a flashlight through the tin cover hole if you think you are getting too much grease that might find its way to the clutch.
CJD
I no longer have the need to see grease come out...with a couple exceptions. Small bearings, like the cross shaft, get one pump at every oil change. That’s plenty. The exception to this are my trunnions. They get pumped until clean grease is expelled.
Also a bit curious...where did your retaining bolt go?
CJD
Interesting. I referenced the parts catalog and it doesn’t show it either, in the photo or description. Both my TR2 and TR3A had the retaining bolt, though. The TR4 box I later rebuilt did not have the bolt, but I can’t remember if the 4 had the hole for it or not.
S
Snowkilts
My 3A appears to have holes on both sides. Not sure if they're threaded or not. No idea if it's the original transmission or not though.
RJS TR4/4A Clutch Slave mount into cross shaft Triumph 3
hondo402000 TR6 TR6 Clutch cross shaft Triumph 9
71tr clutch cross shaft fit Triumph 4
J TR6 TR-6 Clutch Fork Cross-Bolting ? Triumph 2
D TR6 HVDA TR6 Installation and SPEC Clutch [Cross post] Triumph 2
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
T TR2/3/3A TR3A clutch problem Triumph 15
S MGB 1978, replacing the clutch. MG 3
S MGB clutch replacement MG 7
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
