TR2/3/3A Cross reference for hardware
GilsTR
A number of years back Moss Motors had a TR6 catalog
that had on a reference sheet showing
part numbers and the size of the bolt / nut / washer / screw etc.
While I do not mind buying some hardware from our vendors...
having this handy sheet saved us so much time during the
restoration project. Missing a bolt...you immediately knew the
size....and stopped at the hardware store...found the Grade 8
inventory...and I was on my way.
Somehow in moving the shop from one location to another I
lost this valuable sheet.
Do any of you happen to have a copy of this that you would
be willing to either email or snail mail to me?
Thank you for your consideration.
Gil NoCal
DavidApp
Is this the one you were looking for?
It exceeded the limit on the forum. PM me and I can e mail a copy.
David
DavidApp
They came through OK. E mail sent.
I have seen the suggestion on another forum that if you post an e mail address you use (at) not @. People get it Bots don't.
David
M_Pied_Lourd
I also like the back of TRF's TR250/TR6 Glove Box Companion. It has them listed as well.
Cheers
Tush
CJD
You guys are trying to take one facet of the fun out of the restoration. Part of the attraction is using a long bolt to dig through your boxes of old bolts looking for that single bolt you need out of the thousand or so old bolts you have!
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
H gear reduction starter cross reference Austin Healey 12
aeronca65t Spark Plug Cross Reference Restoration & Tools 3
PAUL161 Spark Plug Cross Reference. Restoration & Tools 1
T Helpful cross reference site for parts Triumph 6
T TR4/4A Fram or other spin-on cross reference for TR4a Triumph 7
H Cross Reference Source Triumph 5
roscoe Filter cross reference Austin Healey 3
A Headlight Cross Reference Spridgets 3
Y Cross Reference on Brakes for Europa Lotus 2
bmurphy7369 XJ6 S2 vs. XKE S3 Mirror Cross-Reference? Jaguar 5
S MGB Transmission cross member re-install MG 14
Healey Nut Cross Rod Correct Length Austin Healey 14
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
S TR2/3/3A Clutch cross shaft bushings? Triumph 5
F TR2/3/3A Throttle linkage cross rod Triumph 4
G 100/6 Radiator cross member Austin Healey 6
R Wanted WTB Spitfire race/auto cross car Triumph Classifieds 1
J TR6 TR6 Cross Tube Differences? Triumph 6
J front cross member height from bottom to floor on BJ8 Austin Healey 5
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
S Difficulty removing end rods and cross rods Austin Healey 11
S TR2/3/3A cross tube back on Triumph 3
J E Brake cross rods Other British Cars 6
PatGalvin TR2/3/3A Engine Cross Tube Challenges Triumph 6
RJS TR4/4A Clutch Slave mount into cross shaft Triumph 3
oxford steering cross rod Austin Healey 13
stuntflyr Solo cross country Healey frame transport. Austin Healey 17
Boggsy64 MGB Front Cross member pads MG 4
G 100-S in 1000 K cross country race Austin Healey 6
C 1500 gt pre cross flow Other British Cars 4
andrea Austin Healey 100/6 cross flow heater pipeclips Austin Healey 3
M TR4/4A TR4A muffler hanger to cross member attachment Triumph 13
C Ford 1500 Kent Pre-Cross Flow Mystery Lotus 20
bighealeysource Question on toe in and cross rod assembly Austin Healey 4
F Bias ply tires [cross ply tyres]- more for less? Austin Healey 36
J TR6 TR-6 Clutch Fork Cross-Bolting ? Triumph 2
G Auto cross tire pressure Spridgets 7
T MGB MGB cross country trip - NY Times MG 0
K TR2/3/3A TR3 Boot: The criss cross support bracket Triumph 2
Got_All_4 Auto cross videos from TRF Summer Party 2010 Triumph 0
T TR4/4A TR4/A cross-tube question Triumph 9
Nigel_Johnsfolly LBC Cross-Country Rally Other British Cars 2
Nigel_Johnsfolly LBC Cross-Country Rally Spridgets 0
I Bugeye spares supplies for a cross country trip? Spridgets 13
mjobrien Top cross section at the front header / bow Austin Healey 0
Lynn Kirkpatrick MGB-GT MGB-GT Tranny Cross Member MG 5
M Wire wheels- cross fitting Spridgets 12
hondo402000 TR6 TR6 Clutch cross shaft Triumph 9
